High voltage battery replacement
Discussion in 'Model S: Battery & Charging' started by KL670, Nov 29, 2017.
  1. KL670
    KL670 Member
    San Francisco
    I was just told that my p85 high voltage battery needs to be replaced. Does that mean the actual battery pack? I hope it’s not too stupid of a question.
  2. SSedan
    SSedan Active Member
    Greenville Wisconsin
    The specification of high voltage would seem to mean yes, there is a small 12volt battery as well which is a common wear item.
  3. Fusion
    Fusion Member
    San Francisco
    What was the issue that they had to check your car to determine this? Just curious.
  4. KL670
    KL670 Member
    San Francisco
    My car was in the service center for some cosmetic work but they found a fault in the battery system and determined that the high voltage would have to be replaced.
    I guess I should be happy they’re repacking it?
  5. scaesare
    scaesare Well-Known Member
    NoVA
    My 2013 B rev. pack had to be replaced. The reman D rev pack I received had slightly better range than my old.
    I wouldn't sweat it.
  6. KL670
    KL670 Member
    San Francisco
    What difference have we noticed in terms of the different generations of batteries???
  7. cassiri
    cassiri Member
    My P85DL is getting the battery pack replaced. I just heard that it will be a 90kwh pack. They say it will have more range but not more performance than my 85 pack. I guess that means still 1500amp not V2 battery with 1600amp? Would be nice to get more performance but better range isn’t bad. I asked about paying for a 100 pack but was told not possible as others have heard.
  8. KL670
    KL670 Member
    San Francisco
    Will yours be rebadged to P90D then? If they replace mine with a 90kwh battery, it’ll be funny situation with the rebadging since mine is an P85.
  9. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    Yes, others have reported that they rebadge the car and update the configuration to show that it is a 90kWh car on the screen. Which I guess means your DMV registration information becomes out of date?
  10. KL670
    KL670 Member
    San Francisco
    And mine may become the unicorn of P90 :D
  11. jaguar36
    jaguar36 Active Member
    NJ
    Based on the data on the degradation of the 90 packs, I would refuse a 90 if they tried to swap my 85 for one. You should demand either an 85 or a 100. With the 90 pack in two years you'll have less range than the 85 would have.
    • Like x 6
  12. KL670
    KL670 Member
    San Francisco
    Appreciate the advice. But honestly do I really have the right to demand an 85 or 100 pack? I’m sure they’d tell me they ran out of 85’s and could only upgrade me to a 90. Has anyone tried to demand a 100?
  13. jaguar36
    NJ
    Sure, you are entitled to an equal or better replacement. The 90 is clearly inferior. Although I suppose it depends on how long you're going to keep the car, if you're only going to keep it for a year or two the 90 might be better for you.
  14. KL670
    KL670 Member
    San Francisco
    Would you be so kind to direct me to some relevant threads that speak to the 90kwh battery problems? Thanks.
  15. cassiri
    cassiri Member
    From what I have read on forums I thought the inferior batteries were the ones installed initially on 90 vehicles and that since that time the chemistry and other components had changed. I will certainly ask more questions when I pick up, but happy at least in the short term to get my car back with more range. If I “broke” an 85 battery in 2 years I will likely break a 90 again before the warranty is up?
    They did point out that performance would not be changed which is interesting.
    Given all that I doubt it will get rebadged.
  16. jaguar36
    NJ
    Sure its this post.
  17. agloutney
    agloutney Member
    Montreal
    Please let us know what you find out about the battery chemistry in the new 90s. I now have a unicorn 90 (nonP) with a September built 90 HV pack. I'll be watching degradation closely but it would be nice to have a larger sample size.
  18. cassiri
    cassiri Member
    Haven't gotten my car back but just noticed that my Tesla app shows my car is now a P90DL, not a P85DL due to the battery change. I was told this would not be the case, but the app is clear. I assume they will change the trunk badge as well. I am kind of excited but have some mixed emotions since back when the P85D came out it was such a thing. Now things have moved on to P100D so the shine is off.
  19. KL670
    KL670 Member
    San Francisco
    So the car is still st the shop but when I checked my app, it now says my car is a 90, not a P90 or 90 D.
    Is there such a thing as a 90? I haven’t talked to the sc but I wonder how it affects my car’s performance.
  20. MP3Mike
    Oregon
    There is now. :)
    • Funny x 3
