High Wh/MI for 5 minute drive. Over 600 at times. Anyone else have this issue?
Discussion in 'Model 3' started by steven415, Sep 15, 2018.
  1. steven415
    steven415 Member
  2. Linkeds2
    Linkeds2 Member
    Norcal
    Do you have max ac or max heat on?
    Check your tire pressures.
    Turn regen braking to low and see if your coasting feels restricting (if possible).
    You could have something binding on the drivetrain
  3. fr100
    fr100 Member
    Northern CA
    Do you park in the sun? Try turning off the A/C for a few drives and see how it performs.
  4. kbecks13
    kbecks13 Active Member
    SoCal
    High consumption on a brief drive is totally normal for HVAC reasons like others have said.
    What type of Model 3 is this? 280 is kinda high for a lifetime consumption (at least for a RWD). I think mine is more like 245 and i would say i drive spirited plus use lots of AC.
  5. ebmcs03
    ebmcs03 Active Member
    So Cal
    It’s takes a lot of energy to get a car moving. So if your 5 min drive is all stop lights. It’ll be high useage.
  6. Maximilien
    Maximilien Member
    Irvine, CA
    First 5 min of driving will always be high Wh/m because you had to move the car from rest.
    It is normal to get 400~1000 wh/mi during that time. Worse if you have AC or heater on.
    Now if you get 1000 wh/mi after driving 20 min of relatively flat highway, then you got a problem.
  7. novox77
    novox77 1.21 Gigawatts
    NH, MA
    Elevation could be a factor too. Anyhow, 0.9 miles is not enough distance for an efficiency rating to stabilize. a combination of elevation, HVAC use, and start/stop speed could easily account for this.
