Highest milage on a Roadster?
ffylling
49
2
Norway
Can anyone confirm what is the highest milage on a Roadster so far, on original battery pack?
it would be grate to know how long it has driven, what kind of "problems" and the condition of the battery?
dj905
213
40
GTA, Canada
I have 58,000 km (36,000 miles) on my roadster 2.0, purchased in May, 2010. No problems with the battery (original). I am now getting 285km on a standard charge, and do Range charges about 5 times per year.
I think that my roadster may have the highest mileage in Canada (but we have a small community here).
Regards,
David
samcarney
Sam C
May 22, 2009
261
16
Great Lakes, Sonoran Desert
Regards,
David
I've had my Roadster 2.0 since August 2009. 32k miles. I get between 178 - 170 miles on a standard charge. I also Range charge 5-6 times a year.
At 3k miles I had a minor internal problem with the battery. Chicago area did not have the facilities to repair the battery so I got a replacement (new I think/hope).
I replaced the PEM fan at 31k aside from that no problems.
wiztecy
2,905
563
Some good data points to add:
-When your Roadster was built and hit the road
-If your roadster is a 1.5, 2.0, or 2.5, or a 2.5 sport
-Your driving and charge habits
-Has your Roadster be been sitting idle / in storage and not driven for any long period of time
-Typical ambient temps the Roadster is driven in
This should help others out and give us more insight in on the battery life and conditions.
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
For comparison purposes, mine is a 2.0 with 32k kms (20k miles), coming up on three years old. Standard mode charge comes in around 285 km (178 miles).
wiztecy
2,905
563
1.5 Roadster - on the road since apr'09.
Sat for 2+ years at menlo park with 3,800 miles.
Roadster has 14,000 miles on it now running the stock AD07s still, waiting until the steel belts show on the inside rear camber to swap over to the AD08s on the back. A couple more day's left of rubber I'm thinking....
Std. mode charge: 181 miles
Range mode charge: 232 miles
I try to do thermal cool downs on the pack whenever I get the chance. Also don't do that many range mode charges. 4 since the lifetime of the car, mostly... one for curiosity and 3 done as a balancing experiment. I'll try to do 1 or 2 a year just to keep the pack happy and fully balanced. Also don't stomp on it below 40% SOC.
stopcrazypp
9,875
4,801
I have been told that he always charged using 380 V voltage. I think that if he had always charged with lower voltages (220 V, 110 V) he would have got even more miles.
I don't think the voltage at the socket matters (it'll always get converted to the same charging voltage at the battery), it's the power.
Raffy.Roma
3,253
11
Rome (Italy)
Yes but in Europe we don't have (unluckily) superchagers like you have in the USA. For us the fast charge is done using 380 V voltage. So also the current amperes I suppose are higher for a 380 voltage. Then P=VI
Raffy.Roma
3,253
11
Rome (Italy)
"I try to do thermal cool downs on the pack whenever I get the chance"
Can you tell me more about the thermal cool downs?
I also would like to know more about thermal cool downs in particular when the car is being driven. Does the AC work to cool down the battery also while the Roadster is driven?
wiztecy
2,905
563
"Thermal Cooling" of the pack mean using the 220v charger to run the HVAC system on the car to cool the battery pack down. Tattler has this feature, have to do it manually on the OVMS although I believe it will be added later when there's resources and time on the project. If my battery temp is >26C I plug the Roadster into the charger, set the AMPS down to 12amps to cover the HVAC system, and allow it to run for 30+ minutes or until my target temp is reached. If its a hot summer day and the battery pack is heated above 30C I then set the charge Range mode and with the same amp setting. I'll turn on / off the charging 2-3 times. Range mode is more aggressive with the HVAC cooling. If your not plugged in I believe the HVAC system will run if the battery temp is extreme, I believe 40C+. It uses lots of energy to run hence why its not automatic for the most part when the Roadster is unplugged. For this to work on 110V I believe you need at least 20AMP at the plug or if you have 15AMPS the temps have to be above 36-38C to kick on.
hcsharp
3,370
1,337
Vermont
Not much you can do while driving except drive in standard mode which cools the battery more than it does in range or perf mode. Once you stop, follow Wiztecy's directions ^^^. Charging in range mode for a few minutes at 240v (low amps) cools the battery to 17C.
rugbymonk
Roadster #287; S Sig #14
Apr 25, 2010
34
3
NJ
54k miles
2008, 1.5; battery replaced at 20k
Commuting to NYC almost every day, scrapping it out with busses and potholes.
Standard charge to about 162 miles now, range mode to 190 less than 10/year.
