But the induction motor efficiency does not actually reach zero with your stated test conditions, it is a much larger number than that (infinitely larger in fact). As long at the motor is moving the power efficiency is definitely non-zero.
I do not have any specific performance data for the Tesla induction motors so I cannot indicate what the efficiency for those would be under your assumed testing conditions. Driving at 81 MPH is legal in some states in the US, but finding a location with a constant 80 MPH wind is rather problematic. I also do not have any access to a sufficiently long, or dyno equipped, wind tunnel to drive at 1 MPH in an 80 MPH wind (which is all really quite sad, but true).
However, the modern internet makes numerous technical resources readily available so that I can easily provide a link to a technical paper that evaluated induction motor efficiencies over a range of speeds provided by a VFD. An IGBT Variable Frequency Drive (VFD) is what is Tesla uses to control the motor power and RPM. The bottom line is that the loss in efficiency at lower speeds is actually relatively low, at least with the motors and inverters and the testing conditions they used.
However, they only evaluated these motors and inverters over a 40% to 100% relative speed range. Fortunately with the wonders of modern computers we can trivially plot their data and even extrapolate it back to essentially zero RPM (1 MPH out of 155 MPH is close to zero, but not zero). I have attached a screenshot of the resulting plot, and as you can see the efficiency under load at near zero RPM with the motors and inverters that they used (which are obviously not optimized for the wider speed range that Tesla requires) still comes in at about 73% efficient. I would not be at all surprised if Tesla does significantly better than that the tested motors and inverters over your assumed speed range.
The Tesla induction motors are actually built in-house and they are *very* efficient since they use higher conductivity copper rotors, while common industrial induction motors use lower conductivity aluminum rotors for a lower materials cost. Copper has about 66% to 71% higher conductivity than aluminum, while the best room temperature conductor (silver) is only about 5% better than the best copper. The Tesla inverters are also surely optimized for the extremely wide speed range their vehicle requires, rather than what is usually required for most industrial induction motors.
And since we are now talking about induction motor efficiency at very low RPM, we have also entered the realm where viscous and other related losses also become vanishingly small, etc. At low speeds but with significant torque loads many frictional losses become insignificant relative to the torque being produced.
http://digitalcommons.calpoly.edu/cgi/viewcontent.cgi?article=1004&context=bae_fac
