Maybe the regen is massive, compared to MS / MX ... but if not there wasn't enough run-out to slow the car with current levels of regen, so brakes would have had to be used. Either way 30% SoC had been used up at the point in the evening when the video above was shot, so high speed runs were able to be made in high 60%'s SoC
Suppose the power of the Roadster is just double of the current flagship models. That also should double regen. In case of temporary power cells to just give the luanch experience, such a pack could regen up to as much as power output. 1MW output, 1mW input.
With a light car, 1MW (extreme case) of regen does a good amount of slowing
I'll add though, that I did seem to hear the sound of disc brakes bringing one of the cars to a standstil from low speed.
In a 0-70-0 situation where the 0-70 didn't take a lot of time, the relative efficiency due to regen improves due to the ratio of kinetic energy versus the distance (air) travelled (through). The power (cell) pack may be both lighther than the production version, it could also provide better regen than we'd expect at current state of commercial (range) battery tech.
We don't know what these roadster prototypes weigh.
What we do know is that they offer significantly more power than P100D's. Unless...the road is really, really light, which I personally doubt. Intuitively, mostly from the tire noise and its fluent movements.
I truly hope that Tesla has cracked the triple battery density thing, the Roadster pack will offer 3 times the kWh capacity in a sub-Model 3 sized battery pack. Tesla would be well placed (it's they way of life) to reduce costs. Hopefully, eventually they'll reduce the cost to consumers also. But likely only when the competition does also.
For the S/3/X cars, updated higher density packs would be a great thing. The cars are fine as they are, but more range is always better. It just may not be nearly full after an overnight home charge.
Roadster, when indeed equipped with a 200kWh pack, could do a quick US coast to coast drive. Imagine Tesla building/sourcing a few Megachargers (or CCS350kW) along the route. In Germany, it could also offer impressive A to B trip rivalling petrol car.
I remarked on the reltively low 620mi range for 200kWh. Would drag be so terrible, or could it be the motors being very output performance focused more than economy focused? No small front motor...
