RedMod3
We have 16 panels and a 4kW inverter and we are all electric. We generate 4.4MWh a year and get £1,000 a year cash-back as the panels were installed 8 years ago. Payback was in 7 years.
Don't forget there is the less efficient air-water-air heat pump that heats water that goes to your radiators via pipes, and you may need to upgrade the radiators and if you have microbore pipes, I doubt it will work.
We use the more efficient air-air heat pumps with 4 cassettes in ceilings and one wall unit, and we ripped out our storage heaters so we now have much more space. Advantages of this system are: heating or cooling is near instantaneous and very controllable; you save space over the other less-efficient method; and the very big advantage is you just reverse the system in the hot summer to stay cool. Disadvantage is no government grant and it may be tricky to fit cassettes. We have a 7.5kW and 5kW systems that use an absolute max of 2kW of electrical energy.
