sparkymark75
I went with the HyperVolt. Primarily because it has similar features to the Zappi but cosmetically (for me), looks better.
How do you get the cable to the car out of interest? (assuming you didn't receive grant because no off-road parking?)Just to say that based on recommendation here I had a SyncEV charger installed yesterday by EVC Installs. Ben was easy to deal with, good communication. The install was delayed a bit because the DNO needed to upgrade the fuse and I needed to upgrade the meter tails before that but Ben was quickly available once I was ready to go.
Install was outside a Victorian mid-terrace in central London so didn't receive the grant.
Had our first Zappi installed In 2017 for the Outlander. Second one added in 2018 for the Ioniq.I’m planning to buy/lease a M3 towards the end of the year and currently upgrading the circuit breaker box and running the required cabling to the outside wall where the charger will be located In readiness.
I learned that the U.K. OZEV grant isn’t available for the Tesla Wall Connector so I’ve been researching various 3rd party chargers and, of course, there are a bunch of conflicting views on the pros and cons of the various offerings.
I’m inclined to spend a little more to go with a better quality and better supported product however and want to avoid the need for an earth rod and want decent customer support.
The Zappi charger appears to tick all the right boxes however I thought I’d seek the opinions of Tesla owners who’ve already been through this odyssey and come out the other side laughing.
Another interesting product is the HyperVolt (again, in the U.K.) so I’d be grateful for any helpful comments.
Thanks in advance!
People in my area string it across the pavement in a plastic pedestrian cable protector. The council recommendation on this is it's not advised, but not banned either.How do you get the cable to the car out of interest? (assuming you didn't receive grant because no off-road parking?)
I see the AA now cover public liability in regard to charging cables, i.e people tripping over them...People in my area string it across the pavement in a plastic pedestrian cable protector. The council recommendation on this is it's not advised, but not banned either.
I have a Tesla M3SR+ and charge with a (bespoke design) Viridian charger.A point to consider when selecting a home charger is. If you only use the charger for a Tesla, you can either use to basic Tesla charger or set a smart charger to basic mode and let the Tesla set the start and stop times.
However, if you have a second EV, like we have, a Smart EQ, this car cannot set start and stop times and as soon as you plug in a charging lead, it charges straight away if there is power on the cable, so I am reluctantly using a granny cable connected to an Economy 7 supply and have to run the car down to 20-25 miles remaining range to bring the charge up to the optimal 80%.
The alternative is to use the smart feature of a smart charger, but my SyncEV cannot delay charging unless it sends 6A pulses every 3 minutes (so operating relays in the car each time) to keep the car awake, or sending a constant 6A charging current. Currently, there is no option to optionally not send the 6A pulses, but SyncEV have said they will try and solve this issue.
So, my question is: on the chargers you have had installed, if you wish to set either a charge amount or a charging period, does the charger you have selected allow you to delay charging without sending pulse/charge to the car in the meantime, and has your preferred installer commented on this?
I have a Tesla and SyncEV chargers.
As Somex says, you can't set start and finish times in the car, only the start time and approximate the finish time by guessing what percentage to add. Using 'departure time' to stop the charging is also pointless if you are not actually leaving at that time, as energy will be used to pre-condition the battery. This is a flaw in the Tesla software but could easily be fixed and hopefully should also be picked up in the app.A point to consider when selecting a home charger is. If you only use the charger for a Tesla, you can either use to basic Tesla charger or set a smart charger to basic mode and let the Tesla set the start and stop times.
The charger(s) are built into the car, the EVSE (the box most people refer to as the charger) should contain a variety of electrical safety features and necessary plelextrixal safety protection together with signal and handshaking between it and the car. It’s not just an electric source with a cable and plug to connect to the car.i have three phase supply in my house. i have a power supply in my garage which says that max Ampere is 45 A.My query is that do i need a charger or simply use the socket to charge my model3 tesla.
I believe i can schedule charging time of my tesla by tesla mobile app??
Do i need some commando socket etc ?
Also, does buying a charger like pod or zappi makes any sense?
please advise.my tesla would be coming sometime in Oct-nov.
cheers
You can't.I believe i can schedule charging time of my tesla by tesla mobile app??
Thanks for comments, and yes, I made an error as on a Tesla you can set the charge start time and battery percentage.The charger(s) are built into the car, the EVSE (the box most people refer to as the charger) should contain a variety of electrical safety features and necessary plelextrixal safety protection together with signal and handshaking between it and the car. It’s not just an electric source with a cable and plug to connect to the car.
That electric source can be used to feed the chosen EVSE
Please accept my apologies if I misunderstood your original postThanks for comments, and yes, I made an error as on a Tesla you can set the charge start time and battery percentage.
My comments were for if you are not just charging your Tesla, but another EV that cannot set charge start time and percentage battery. Will your choice of charger work with the other EV (as well as the Tesla)
I’m glad ENW are doing something, I had a survey done almost 2 months ago and now they say we need another before we can be unlooped.Finally been unlooped, just hope they come back tomorrow to reinstate/make good, as PodPoint are installing on Thursday!
(already in the neighbour bad books as road is a mess)
I went with an Ohme charger, great setup and plenty of control through the app. I think you can now use the app on any brand of charger as it connects to the car. I have it set up to charge when my Octopus Go Faster hours are cheap and get it to 80%. Set it up once and now just plug in. Easy as pieThanks for comments, and yes, I made an error as on a Tesla you can set the charge start time and battery percentage.
I've not been impressed with the crews that did the road works, they just turned up and started digging and have left the street and neighbours garden in a right mess (over the bank holiday too). I'm assured a clean up crew will be out today. Actual unlooping work took about 10 minutes and my fuse was replaced with a 100a one. (they just snipped the cable and tape it off)I’m glad ENW are doing something, I had a survey done almost 2 months ago and now they say we need another before we can be unlooped.
Due to the delays, the person handling it are trying to get permission from another department to allow the charging point install to go ahead as long as I only use it at night.
