Pretty sure my Ohme doesn't either.
Does the Anderson need an earth Rod?
My Ohme wall charger does have an earth rod.
Still think most charge points out there do need an earth rod to comply with UK regs.
Between now and ordering, if you have not got a Tesla referral code/link in mind, please consider asking someone who has given you prudent advice for theirs. You will then both benefit from some free supercharging miles.
In the interests of trying to not spend a huge amount of money are there any suggestions on charge point that are cheaper than the Andersen that are decent? I spoke to the installer about the Tesla Wall Connector, which is cheaper but requires a type B RCD fitting which is circa £200 and takes the cost up towards the Andersen.
The Anderson range look very nice, but they are very much at the top of the upper end when it come to price. A basic charge point can cost as little as £250 to buy, it's almost always the installation that is the lion's share of the cost, although sometimes it does seem as if the availability of the grant pushes prices up a bit.
I did a breakdown of a budget installation materials cost in this thread that might give an idea of what things cost: Basic charge point costs
Supply cable length doesn't make a massive difference, roughly £3 per metre or so, plus the additional time to install the cable.
Best bet might be to contact a reliable local electrician who is familiar with charge point installations and discuss options. Some charge points don't require a Type B RCD now, as they have integral DC tolerant earth leakage protection, and one or two don't need to be wired as a TT installation, to provide open PEN protection.
Much of the installation cost comes from the more awkward parts of the "mechanical" installation, running cables through awkward spaces, finding the best location for the supply end parts, etc Actually wiring up the charge point and the supply end is maybe only about 20% of the work (and cost), and so you may be able to reduce cost by agreeing with an electrician some DIY work you can do, to make things easier and quicker.
Normally a charge point installation shouldn't take more than a day at the most, and often they only take three or four hours. The labour cost shouldn't be that high, depending on what prices are like where you are. Here, in the south, we pay around £220 per day for a decent electrician, but for somewhere like London the rate is typically closer to £400/day. Not sure what the rates are in your neck of the woods, but it's unlikely they'd be higher than London prices.
Thanks for that - very informative post. I was told that doe to the 32 metre length of the run I'd be in for a thicker cable due to voltage drop over the length. I guess not knowing if you will get the grant until after arranging install also plays a part on deciding. Reading some "do i qualify" FAQ's it would appear I'm borderline...
If you decide that you’re not eligible for the OLEV grant I’d certainly consider the Tesla Wall Connector. The unit itself is £360 from Tesla, but you’ll probably be looking at a total of £1000 fitted.
Before the Tesla I’ve had a Leaf and a Kona electric, and had a Rolec charger installed under the grant in 2015. I had it swapped last year for the Tesla unit and the build quality is like chalk and cheese. The old Rolec was light and clunky, the Tesla is very nicely finished. You also get the advantage of the button on the plug to open the car charge port.
Another possibility is to use the Ohme charger that plugs into a commando socket. If you sign up to Octopus they sell them for £200. It has a built in DC fault current trip.
Octopus Energy (Ohme link)
You could maybe use my Octopus referral and we both get £50.
Sadly, the fact that the Ohme has DC tolerant protection makes no difference to the requirement to include DC tolerant leakage protection to the interlocked commando outlet. The regs apply to the fixed part of the installation, not appliances, and the Ohme unit is classified as an appliance, not a part of the fixed installation, so it cannot be included on the EIC and Part P certificates.
The regs are unambiguous, in that any electrical outlet that is intended for charging an EV* has to comply with the requirements of Section 722 of BS7671:2018, Amendment 1. This means that an interlocked commando outlet (and it must be interlocked - there is a need to ensure that the power is turned off before the connector can be removed) must have both DC tolerant earth leakage protection and open PEN protection.
The reason for this being a mandatory requirement is because there is no way of knowing whether or not an appropriate appliance will always be used with any outlet. Someone may plug some other charge point box into the commando, that doesn't have adequate DC leakage protection, for example.
* It isn't just EV charging that has the requirement for open PEN protection and suitable RCD protection, either. Any outlet that may be connected to anything with exposed conductive parts, such as a heater in a metal shed or greenhouse, or a caravan power supply, also needs to have open PEN protection and RCD protection. This is a long-standing requirement, that goes back earlier than the current edition of the regs (I think it came in with either the 16th or 17th Editions).
Well that's all a rather expensive pain in the posterior isn't it ?
