I also vote "use what you have, first, and if it becomes annoying plugging and unplugging the adapter, then get a wall connector".
"most" people will not need the difference in speed of. charging between a 32 amp circuit and a 48 amp one, but saying that, it sure is nice to "charge at full speed". My normal commute to work is 80 miles round trip, which is about 80-120 "tesla miles" depending on how I drive, weather, etc. I can "refill" my car from my daily commute in between 2.5 to 3 ish hours.
Not "necessary" but completely, utterly kills the "range anxiety" issue for me of wondering "what if I have an emergency after getting home from work, and need to take the car blah blah blah blah??!?!?"
Not like it has ever happened, but this is my first EV, and such thoughts crossed my head in 2018 when I bought it. I would buy the HPWC again, even though I now know that I dont "need" the charging speed, because I like how it looks, and it makes charging time a complete non issue. Even if you are on a time of use plan where your "cheapest electricity" is midnight to 6 am, you could completely refill your car within that time frame on a 48 amp circuit, even if you just got back home from a trip basically on "empty".
Still, not "needed" and you already have charging infrastructure in place, and if I remember correctly, stated you were retired or about to be, so can likely control your commute times / distances as desired.
EDIT:
One more thing....
The problem with a "consolidated charging thread" is that setting up charging for your car at home is somewhat like a construction project. There really is no "best", because it depends on your electrical infrastructure in place, or able to be placed, your desired to spend money to upgrade said infrastructure if needed, how far you drive and how often you need to charge, etc.
Still, with that being said, the "fastest" way to charge a tesla at home is the HPWC (tesla wall connector). In almost all cases, that solution will charge fastest, but that doesnt necessarily make it the "best" for each person. I know that may not help, but thats what I got, lol.
