It's certainly true that it will be much cheaper than gas, but you're missing out on some factors which, in real world use, will make them a bit closer than your calculations. First, batteries aren't perfectly efficient in round-trip charging. So, in order to get the 20 kWh of useful electricity out of the battery you probably have to charge it up with between 22-25 kWh from the grid. Also, while you may be getting 200 Wh/km during the actual driving, if you're preheating the car while it is still connected then you'll be using extra "shore power" to warm up which won't be reflected in your driving efficiency. Also, the car has some small amount of vampire drain that will lose charge without doing the "useful" work of moving you places. The end result is that you're probably actually paying closer to $3.00/100km. But even that is going to put you well ahead of gas.
