Is t UK already 220/240V? You’ll charge at a decent rate with the included charger.
Came here to say this; I live in Boston MA USA where it gets pretty cold over the winter, probably colder than most of the UK.
I get by just fine on a 240/20A charge circuit.
If you have time-of-use adjustable costs for your charging and the charging costs are huge, it may make sense to have a higher power circuit installed. If you have a huge commute where you'll need a better than 10 hour turnaround and don't have superchargers around, maybe you'd need a better circuit.
I got the 240/20A circuit because it was cheap / trivial to install. I got it as a test to see if it would be fine or if I'd need to invest in a higher power circuit rather than jumping straight to running new wire, upgrading the house's breaker box, pulling a new feed from the utilities, relocating the meter, etc (IE a huge investment). I also had a convenient charger at work, but haven't been going to the office for more than a year...
I'm not knowledgeable about typical UK circuits, but it looks like a a 13a circuit may be somewhat normal, which means you'd charge at 10A (assuming circuits in the UK are rated for 80% load continuously, again a wild-assed-guess) -- my 2016 90D charges at 7 miles per hour at 10A/240. Is the car going to have to drive 100 miles per day or more (assuming you can just leave it on a charger / in the driveway for 14 hours per day)? It looks like a 32a circuit is also pretty common; if you have one of those you'd basically have a totally usable charging setup.
These solutions assume you'd have a normal outdoor outlet with expected protections (high duty cycle plug, weatherproof box / GFCI), a mobile charger plugged in "permanently" and a way to secure it against theft / mechanical wear. I'd recommend buying a 2nd tesla mobile charger for this with the appropriate adapter for whatever plug you get. I'd expect this to cost far less than your original quote. It'd be slightly less safe and slightly less robust than a hardwired charging setup; for instance you could do stupid things like unplug it naked in the rain while standing in a salt-water puddle; that should still be safe (With GFCI protection) but *I* wouldn't try it... Also the plug could wear out and overheat if you plug/unplug it more times than it is rated for.
