i am having issue using charger with my 220 charging plug. Had my electrician check new circuit, 14-15 and fuse and all is good he says.
When I plug my charger into wall outlet all is good and green Tesla lights up like it should. Then I plug into car and the charger cycles through the letters twice then the Tesla t on charger turns red and no charging begins. Manual states some sort of ground fault inteuption but that doesn’t seem to be rhe case. This is sporadic and if I unplug from outlet and rep lug cable back,in sometimes it then stars working fine. I borrowed my neighbors 220 plug and I could not reproduce the problem. So I assumed the pigtail cable was the issue and I called for service. I was supposed to have ranger come to house but they never called so I went to local service center. They tested my charger and cable and said all was fine but gave me new 220 pigtail. I plugged in at home and same issue. Red t then juggle plug /unplug and got it working again.
Has anyone experienced anything like this or thoughts on what if anything could be wrong with outlet maybe that allows this to sporadically work?
Thanks
Doug
Thanks
Doug
