Hi Friends, I’m in the midst of trying to figure out a location for my charger. Unfortunately my house driveway is less that ideal for locating a charger. Distance from the electric meter to the proposed locations have been too long to be covered by pod point or EO without exceptionally expensive additional work. I’m now wondering if I can get around the issue by asking an installer to place an EV charger compatible post into the ground next to my fence? Am I correct in assuming the fence posts (the solid wooden posts that connect fence to fence) are definitely not possible due to fire hazard? Does anyone have any experience of installing home chargers in this way (ie not against a brick wall)? Thank you so much for your thoughts!
No problem in the regs with fitting a charge point to a timber post, just done this myself yesterday (see this post: DIY charge point ). There's nothing much in a charge point to cause a fire hazard, anyway, it's just a controlled mains switch and outlet, there's no high power charging circuitry in it, as the charger(s) are inside the car.
