I have 2 locations where I will look to install charging at better than 13A. One three-phase and the other single.
I'm sure this question has been asked many times (and I have read a few) but I'm still not quite there on my options. Am I right that they are essentially:
Tesla: Best and priciest
Limited to 7kW for “most homes” – is this an installation on single phase, where the charger runs at its theoretical maximum of 22kW on 3 phase?
Regarded as best, but why? Just for the button to flip open the charging port?
Next best thing: other wall mounted EV chargers, like Pod-point which is £359 after grant for single phase 7kW or £999 after grant for 3 phase 22kW.
What are the pros and cons for these vs Tesla and what other brands should I consider?
Cheapest: "commando" socket running 4kW on single phase or c.11kW (16Ax230Vx3) for 3 phase.
What I'm looking to understand a bit better is - what are the reasons for Tesla over the others and what are the differences between the others? If not Tesla then what do people recommend? For a given connection (3 phase vs single) they are all as near as makes no difference the same current/speed, right?
Subject to installation cost, Tesla might be fairly competitive on 3 phase even if it isn’t on single.
Both my chargers are likely to be outside (although I think I could get either under cover in the long run if it makes a difference) and used more than once a week, so I think tethered cables rather than taking them with me.
