There are some unused knock-outs in the cover plate and spare bus bar connections in the picture on page 2, so barring a posted limit on # of circuits in the subpanel, you could add another breaker. But the subpanel is fed with #6, so you're limited to 60A total load there (assuming 75 degree wire/connections), so a new 14-50 is tough.If you don't mind running between there and the car location, you could build a 10-30 extension cord and buy an adapter. More realistically you probably need to talk to an electrician. Your garage sub panel does not have enough room for another 220 breaker but your main panel will after pulling that 10-30 outlet.
Actually, SOOW is total number of conductors (the ground is insulated) - romex would be 10/2 or 10/3 (the bare ground isn't included in the count), but equiv SOOW would be labelled 10/3 or 10/4.You wouldn't need a 50' extension. The UMC cable has a 20' cable. Basically he would need a 25' extension that has a 10-30 plug and a 14-30 receptacle. It would need to be marked Tesla Charging Only. I bought this cable to make a 25' 14-30 extension for $30, but it isn't available at Home Depot anymore.
Cerrowire 25 ft. 10/3 600-Volt Black SOOW Cord-283-3803A - The Home Depot
It has an extra wire he doesn't need, but could easily be wired with the proper plug and receptacle. With only 100A service for the house and the fact he has pool pumps, 24 amps is the max I would be comfortable charging at anyways. The Mobile Connector 14-30 adapter was just made available again so I think that is the way to go.
Thank you everyone for your input, I really appreciate it!!!
If I was to get solar for my house, do they still use my existing panel or do they bypass the panel, or do they install a new panel?
BTW, what is it about CA and their exterior-mounted breaker panels? I've never seen a main panel on the outside of the house, except in CA...
Model3: I'll be honest I dont know what the 50 at the bottom is for, BUT I do not have I do have a gas stove and a gas dryer. I will do some testing this weekend to see if that 50 at the bottom is being used. But I'm thinking either that 50 at the bottom is what is feeding the sub panel in the garage or the very top breaker. I do have a trusted electrician coming on Monday, so I will see what he has to say.
BerTX: I'm hoping the solar company would include that upgrade in the cost, is that something you think would happen?
Or they do a supply-side connection (before the main breaker) and none of the panels are touched.I honestly don't know. I'm sure they have an electrician that does work for them. Likely they will, but it becomes a little cloudy with what is needed for the solar and what is needed to incorporate what they do to make the solar work into the rest of your system. If they come into the main panel, and want to replace the main panel, that doesn't really involve the garage wiring other than hooking up the sub-panel. Now if they were to put the solar breaker into the garage panel, then they would have to replace both panels...
Actually, the probably won't do that unless your main panel is full (no room to add a backfeed breaker) or there is some reason your installation needs it, since it's kind of a pain - they need to get the power company involved to pull the meter and shut off the power before doing the work.Or they do a supply-side connection (before the main breaker) and none of the panels are touched.
A 6-20 would be super easy to install in that subpanel, and offer a decent charging pace using the UMC and the 5-20 adapter with an adapter cable from EVSEadapters.com . It would be the cheapest way to get a decent setup going on this panel, and 3.8kW is nothing to complain about for charging rate unless you need to do back to back long trips with no Supercharging on the route. Even a 6-15 with the stock Tesla adapter would be 2.8kW which is also plenty for most drivers.There are some unused knock-outs in the cover plate and spare bus bar connections in the picture on page 2, so barring a posted limit on # of circuits in the subpanel, you could add another breaker. But the subpanel is fed with #6, so you're limited to 60A total load there (assuming 75 degree wire/connections), so a new 14-50 is tough.
If my Google searches are correct, your Challenger panel is in the same boat as Zinsco, and really should be replaced for safety reasons if nothing else. Hard to tell from the pictures, but it looks like there are already signs of issues... That top breaker (A/C?) doesn't look too good, for example.
One of the many search results:
Is Your Challenger Brand Electric Panel Safe? - Brubaker Inc.
I'd really get the electrician to take a close look at things, ASAP. As in, now.
Oh yeah, that's another reason for a supply-side connection - no 20% limit. Although 20% of 200A gives you 9.6kW, which is still a lot of solar.You are limited to 20% of the rating of the busing in your electrical panel.
