So, delivery is getting closer (I'm estimating around 2 more weeks) and it's not very likely I will be able to get a solar install/service upgrade before I get the car due to the financial consideration (I have to wait because if I get a loan for the solar it might complicate the loan for the car) so once I get the car it looks like my only 2 options are either a 5-15 plug that is around 30'-40' away or the 10-30 outlet for the dryer that is about the same distance away, or drive to an EVgo charging station that is about 3 miles from my house to charge every other day.
**Option 1**
If I use the 10-30 plug, I will need to make an "extension" that has a male 10-30 plug on one end and a female 14-30 plug on the other, then plug the UMC into that. Does anyone have experience making such a thing?
**Option 2**
Get a store bought extension cord for the 5-15 plug and connect the UMC to that
**Option 3**
Drive to an EVgo charging station that is about 3 miles from my house to charge every other day.
So which option do you guys think would be most feasible for a temporary solution (2-3 months max)
T.I.A.
Here are a couple of thoughts on this.
On option 1, I have made an adapter cable—not that specific one, but same type of work. It’s not really that hard. Start with buying a 10-30 cord from Amazon or somewhere, so at least the plug side is already molded on. Then, you can just get a 14-30 receptacle to wire onto the other end. It’s pretty simple and is a good speed charging option. Alternatively, there is a ready-made adapter cable from EVSEadapters that is a 10-30 plug to 14-50 receptacle, which I have. If you use the Tesla 14-50 plug, it will not know the current limit, so that’s not a great long term plan. However, I did hear someone on this forum suggest cutting off the angled neutral of his Tesla 14-30 plug with a Dremmel tool or something similar, so it could fit in the 14-50 receptacles, but would properly manage the current for a 30 amp circuit. That would be a decent idea.
On option 2, don’t just get a regular garden/outdoor type extension cord. Those almost always use 16 gauge wire, which is too thin for long term continuous overnight use of the 12A draw for charging a car. I would go 12 gauge for a 5-15 outlet or 10 gauge if you’re using a 5-20.
You are going to hate option 3—it’s going to get old really fast, so I wouldn’t recommend it. But you could do some combination of 2 and 3 if the overnight slow charging starts falling behind your use.
Some of this is back calculating from how many miles a day you drive. A 5-15 outlet will refill you at about 3 miles per hour. So if you can let it charge for 10 hours, that would be 30 miles. If that keeps up with your daily driving, that would work fine. If that’s not, then you probably should go with option 1.
