Glan gluaisne
Those units look wrong to me. The car cannot possibly charge from AC at 30.428 kW. Looks like there's a mix of units of power (kW) with units of energy (kWh).
If you aren't a fan of smart its possible you may have purchased the wrong car!This is another reason why I’m steering well clear of “smart” anything.
Dumb Economy 7 meter and a dumb Tesla charger for me. Dumb everything in the house (including the owner!)
I don’t want the DNO deciding how fast I can charge my car.
Hi Jeremy, couple of questions:This stuff makes me very glad that my main charge point has a built-in time switch, that's not connected to any sort of smart system. I can flick a switch on the front to select whether I want to charge immediately, stop any charge, or charge only during the off-peak time. I can leave the car set on charge immediately and let the charge point do all the switching on and off, under direct control (as in physical contacts have to close to make anything happen).
The new charge point that I'll be fitting soon has more options, as I've included three selectable charge currents, as well as the same timer system I have in the unit I use most of the time. The main reason for this is to be able to just switch to a low charge rate if it's a sunny day, as I found that the previous system I had for varying the charge rate depending on the amount of PV generation was unnecessarily complex in practice. That worked by setting the charge rate to a value from 6 A (the minimum allowable in the spec) upwards, for as long as the cost of charging during the day was lower than the cost of off-peak charging. In practice, it spent most of its time charging at ~7 to 8 A, so it seemed pointless to have more stuff to potentially go wrong, hence the reversion to a low (7.5 A) charge switch.
- I thought powering on the charger in the middle of the night if the Tesla is asleep results in no charge being taken because the car doesn't wake up. Is this not your experience?
- I'd be interested how you control how much charge the charger offers to the car, and how this is transmitted to the car; is it some sort of digital/analogue thing that is communicated on one of the charge/carrying wires?
Thanks! That's very interesting. Follow on question: so the charge point doesn't *actually* limit the current in any way -- it's just telling the car "please don't take any more than x Amps"?
It’s OK. I just drive it in REALLY stupid wayIf you aren't a fan of smart its possible you may have purchased the wrong car!
Thanks again. I've just looked on the EV Juicenet site, here's the details from last night:
This was it warming up this morning when I put the heating on
13/3/2019 7:48:13 AM 12/3/2019 7:53:37 AM 00:05:24 0.149kw
This was the scheduled charge (start time of 12.30 via the car)
12/3/2019 12:30:01 AM - 4:17:21 AM 03:47:20hrs 30.428kw
This was me messing about turning things on and off last night
12/2/2019 10:23:15 PM - 11:02:33 PM 00:39:18 1.158kw
12/2/2019 10:04:35 PM - 10:12:12 PM 00:07:37 0.22kw
12/2/2019 8:28:38 PM - 10:04:31 PM 01:35:53 2.835kw
12/2/2019 8:07:09 PM - 8:26:06 PM 00:18:57 0.548kw
12/2/2019 7:25:29 PM - 8:07:05 PM 00:41:36 1.217kw
12/2/2019 7 7:23:08 PM - 7:25:13 PM 00:02:05 0.055kw
Total of approx 1hr charging and 6.033kw
This shows (I think) it charging at 6kw during tests and 8.1kw per hour during scheduled charge which gave 119 miles. Is that correct, sound about right?
