So my electrician came this morning to install my Tesla Wall Connector.
In the box is the Wall Connector, the steel mounting plate and a small box with two large self tapping bolts to hold the plate to the wall, an earth wire and the 2 smaller screws that attach the wall connector to its mounting plate.
Here we are at the head scratching phase:
First issue was how to drill the side hole from the inside as described in the manual using the indent as a guide. I'm not aware of any electric drill that can fit in that confined area and drill from the inside so we ended up removing the outer rubber cut-out piece first and drilling from the outside where there is no indent to guide you exactly where to use your hole saw. Geoff my electrician is a careful guy and after a number of measurements we drilled out the hole without damaging anything and he got the position spot-on.
Second issue, was with the largish self tapping screws supplied to attach the mounting plate to the wall. I think they may be designed for Gyprock\Dry Wall, not the masonry we were attaching this one to. He drilled 8mm holes and the bottm screw went in fine but the top screw snapped off one third of the way in! :cursing:
We replaced these with expanding masonry anchors that Geoff had in his truck and these worked a treat, you just have to cut the heads off after you tighten them.
The next bit went a bit over my head as Geoff was asking if the device was single phase or split phase so we rang Mitchell who confirmed it was single phase.
Here it is being wired up.
Once it's wired up, but before turning on the power you set the dip switches to your selected amp rating, 16 Amps in my case according to Mitchell as I have a 32 Amp Circuit Breaker. :-(
Next you attach the ribbon cable from the front fascia plate to its socket on the circuit board and clip the fascia in place, then secure it with the 2 Torx screws at the bottom.
Power on then press and hold the reset button for 5 seconds and the light on the front should come up with a solid green light. Mitchell tells me you shouldn't need to reset the connector every time you switch off the power it should only be an initial system check.
Like others I have an isolation switch adjacent to the connector so I can turn it off for emergencies or when not in use. My garage space is in a common garage area and I am not comfortable with a permanently glowing green light attracting curious visitors so I intend to turn it off when not in use. If you reading this Mitchell I would prefer if I could disable the green light except when actually charging allowing me to leave it powered on.
Here is the finished install that Tesla will be testing tonight if all our chakras align.
