howardnj
kevinf1990Hi all, I just got around to install my 14-50 outlet in my garage. When I finished installing the outlet, I used my multimeter to test the voltages. I tested from hot1 to ground and hot2 to ground both measured at exactly 120v. However, when I measured across hot1 and hot2, I get 208v. I thought that was weird, so I tested the voltages at the breaker with the same result. I measured my other 240v circuits and also got 208v. I then measured at the thick cables coming into the breaker (mains) and it also measured at 208v. Why am I getting 208v instead of 240v? Would this affect charging? Any issues I should be concerned with?
I just read thru the two pages of this thread and I find your question very interesting. I measured the voltage in my garage and my multimeter across hot1 and hot 2 read 242 volts.
I would call a couple of local electricians. Perhaps there is a simple answer or perhaps there is a problem with a transformer that your local utility may want to inspect?
Good luck and let us know the outcome
