An outlet for charging an EV requires (most of the time) a GFCI protected outlet - generally this is done with a GFCI circuit breaker. That'll cost you $100-$150 at Home Depot.
A cheap Levition 14-50 outlet is about $10 ($20 with cover plate/box) at Home Depot. The Tesla recommended industrial-quality Hubbell 9450A or Cooper 5754N is $150 (with cover plate and box). The Bryant 9450R has been recommended as being equivalent to the Hubbell, at half the price. Question your electrician about which outlet they're planning on installing.
AWG 6 wire is about $4 / foot for the 4 wires you'll need. AWG 4 (which is good for 70 amps) will be about $8 / foot, and isn't a bad idea for future-proofing especially for such a short run. You'll also need conduit and fittings.
That's a long-winded way of saying that installing a 14-50 outlet is going to cost:
$150 - GFCI Breaker
$ 80 - High-quality outlet (Bryant), box, and cover
$ 60 - Wire to go 10 feet with usable service loops ($120 if you use AWG 4)
$ 15 - conduit and fittings
$300 for the hardware.
The electrician SHOULD pull a permit and get an inspection. I have no idea how much that'll cost. Let's guess $100.
It'll probably take a couple of hours to do the installation. Call it $150-$250 for labor.
So, something on the order of $600 seems like a minimum cost for a high-quality, permitted installation. Perhaps $100-$200 cheaper if the electrician was planning on using a cheap outlet and works fast.
How can you reduce costs?
- You could tell the electrician that you want the 14-50 outlet for a welder. That means you may not need a GFCI breaker; a normal breaker is $15. Some towns may not require the GFCI outlet for EV charging, if you live in one of those this is a no-brainer.
- You could use a cheap outlet, like the $10 Leviton at Home Depot. If you use a cheap outlet, make sure the electrician uses a torque wrench to tighten the screws holding the wires to the outlet; if he just uses a screwdriver, you run the risk of overheating and melting the outlet (or starting a fire).
- You could find an electrician who will do the job without a permit/inspection. ummm...yeah...not a good idea. Someone who's willing to do this is likely willing to cut other corners that you really don't want cut.
$150 - GFCI Breaker
