Home Installation Cost
Discussion in 'Model S: Battery & Charging' started by IanH88, May 7, 2014.
  1. IanH88
    IanH88 Member
    United States
    I just had a quote for installation of my 14/50 outlet and it's coming in at $2800!!!
    This is due to the electrician telling me that he couldn't pull another 50 amp load from my board, due to the current load, hence he's quoting me for the addition of a 100amp 120/240 EV-TOU and the work that's associated with that.
    My knowledge runs out very quickly in this area and I'm trying to educate myself.....but my question is has anyone faced this issue and what work around did you find without having to spend nearly $3000
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Get another opinion...... Likely the loads you have will not be used when you are charging... at night, when rates are low.
  3. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Where are you located, how big is your electrical panel (amps) right now? How far from the panel is your 50A receptacle going to be?
  4. Blaze
    Blaze Member
    Orange County, California
    I would also suggest getting more bids. I installed a dedicated meter with a new panel for about the same cost you were quoted. This included some stucco patch and running wire from the panel to the garage which was a distance. I received 3 bids and went with the fellow I felt best working with. Happy to have the HPWC.
  5. IanH88
    IanH88 Member
    United States
    Located in Los Angeles, I think the panel is 200 amps and the panel is only 12-15 feet from when the 50A receptacle will be.
    The electrician mentioned one option which was to install a switcher between my downstairs AC and the Tesla socket, so I could only use one of those at a time
  6. mitch672
    mitch672 Active Member
    Stoughton, MA
    If your only trying to stop an AC compressor from kicking in, it's simple to just put a switch on the low voltage line from the thermostat to the compressor, and just flip it when you are charging. A fancier version would use a 240V coil relay, which would energize when your car is charging (basically tapping into the EVSE), when the relay is engaged, the low voltage side of the relay would open the control to the compressor. A lot simpler than any kind of 50A capable AC switching system.
  7. Cosmacelf
    San Diego
    What other 240v loads do you have? (Double breaker size).
