Home monitoring working for you?
Discussion in 'Tesla Energy' started by llngoc, Aug 31, 2018.
  1. llngoc
    llngoc Member
    Bay Area
  2. Sylvia Else
    Sylvia Else Member
    Sydney
    Yes, but the recommended way of referring to the Powerwall gateway often doesn't work if the gateway is connected to your system by WiFi or wired ethernet.
    You'll need to find the IP address that your router is allocating to the gateway, and use that. You'll also have to add an exception to allow your browser to accept the certificate that the gateway provides. You may be able to configure your router to always allocate the same IP address based on the MAC address of the gateway.
  3. llngoc
    llngoc Member
    Bay Area
    Yes. After I posted this, I started using all the allocated IP address on my router and finally got one which worked. (Actually it was the first one on the list so it was not too bad.) But does anyone get the name address to work at all instead of the IP address?
  4. Buckeroo
    Buckeroo New Member
    Australia
    Is there a step by step guide to have your home system connected to the gateway without having to connect via its own wifi so you can monitor all the time?
  5. Sylvia Else
    Sylvia Else Member
    Sydney
    Not really, if the steps described in
    Monitoring from your Home Network | Tesla
    don't work for you. If that's the case, then say what model of WiFi router you have (make and model number), and it may be possible to guide you.
  6. eml2
    eml2 Member
    Massachusetts
    Yes you can if you are using wired ethernet. And I think once you connect to the gateway via ethernet, you can login and configure its WiFi to connect to your WiFi router.
  7. Artimis
    Artimis Member
    Ladera Ranch, CA
    Connect to the Gateway's own wifi as described in the previously posted link. Once you are in, you can access the "Network" section (either as an installer or via the Customer setup) and change your network connection mode. One of the options is "WiFi" and it allows you to connect the gateway to your home's WiFi network so you can monitor it the way you want.
    Personally, I did not have much luck with the built-in WiFi (the range sucks). Instead, I used the "Ethernet" option and wired it into a Netgear range extender (like this one) that was configured as a client bridge to my network. Night and day difference.
