Home Wall Charger how to remove if selling home
DSolie
Pew Pew
Jul 2, 2020
309
654
Olympia, WA
Turn off breaker, pull off charger cover, disconnect power wires, remove wall charger, put wire nuts on the end of each wire (don’t combine wires). Shove the wires into the box in the wall and cover with a plate you can buy at any home improvement store.
thefortunes
1,077
1,268
Wisconsin
One thing I would add would be to put a piece of tape over the breaker (which should remain off) stating something like "disconnected 240v line to garage." Same note should be on the wall plate.
Reactions: DSolie
jmaddr
920
937
Florida
Of course it is dependent upon your specific install, but it's easier than putting in. Without seeing your implementation, I would likely recommend you can have an electrician replace the wall charger for a 14-50 at a minor cost. The wires and conduit will not need to be changed but the breaker will and an outlet added, which "should be" extremely inexpensive. I say should be as if you did it yourself, it's less than $50 in supplies but electricians will likely have a minimum fee of around $200 - $350. Then you can take the wall charger with you to your new home and have it installed there.
So if you have an electrician do it and they charge $300, then is it worth the $200 difference (new ones cost $500 but are constantly out of stock) to have a brand new v3 wall charger instead of moving a used one which is maybe an older generation? Just a choice to make.
