Oh I see sorry, I misunderstood your post. How've you found it? Worth the price?It was a total of $460 for the Homelink module installed, I already have a Model X so I knew my garage door controller wasn't compatible.
It's totally worth it for the convenience of not having a remote bouncing around in the cars, and the garage doors auto open and close when coming and going.Oh I see sorry, I misunderstood your post. How've you found it? Worth the price?
I was watching a few reviews, have you had any issues with the remote not sensing the proximity and failing to open the door? And vice versa for closing?It's totally worth it for the convenience of not having a remote bouncing around in the cars, and the garage doors auto open and close when coming and going.
With model S I’ve found the homelink is too far to reach and the seatbelt holds me back. With a choice of doors and a gate I cannot to auto raise. A very effective solution for the remote was to velcro it to the windsreen next to the camera. Very easy to reach.It's totally worth it for the convenience of not having a remote bouncing around in the cars, and the garage doors auto open and close when coming and going.
Opening has never been a problem, the auto close can be a bit finicky sometimes.I was watching a few reviews, have you had any issues with the remote not sensing the proximity and failing to open the door? And vice versa for closing?
Check the wheels are lubed and clean. Also it might be the bottom limit isn't set right.One of the problems I have with my garage door is that it sometimes sticks when closing (maybe 1 in 50 times) and then opens itself again. So being able to manually press the remote to stop it reopening and then close it again is a bonus. I doubt whether the Homelink system would do that for me.
Most likely the current detection that thinks it has hit something. Might be force adjustable to account for extra friction.Also it might be the bottom limit isn't set right
The problem only happens after a lot of rain - although hasn't happened it quite some time despite all the rain we've had.Check the wheels are lubed and clean. Also it might be the bottom limit isn't set right.
That data kind of invalidates your hypothesis 🤔The problem only happens after a lot of rain - although hasn't happened it quite some time despite all the rain we've had.
Sounds like your door balance might be out and a small breeze makes the door heavier. Place it in manual over-ride and if you cannot lift it easily or if it flies up unassisted then you need to call out a door guy to adjust the spring. Spring adjusting is not a job anyone should do unless they know what they are doing. In manual mode you should be able to raise and lower the door with near equal effort in each direction (roller doors and tilt doors).I have my remote sitting at the front of the centre console next to my phone. It is so easy to just pick it up as I am approaching my home and press it so that the door is open as I pull into the drive. I usually hang on to it so I can close the door as soon as I'm parked in the garage.
It does. Perhaps it wasn't wet weather at all. Or perhaps we've had so much it has resolved the problem.That data kind of invalidates your hypothesis 🤔
The few times I've opened the door manually (when we've had a power outage before I got the powerwall) it has been easy to open and close.Sounds like your door balance might be out and a small breeze makes the door heavier. Place it in manual over-ride and if you cannot lift it easily or if it flies up unassisted then you need to call out a door guy to adjust the spring. Spring adjusting is not a job anyone should do unless they know what they are doing. In manual mode you should be able to raise and lower the door with near equal effort in each direction (roller doors and tilt doors).
I ignored mine doing the same thing and last wek it just gave up and sheered a gear
You have to do the same with many Aus garage doors anyway as they don't natively support Homelink.also need to hardwire it into your existing door opening mechanism, but i got it up and running super easily with some basic wiring
Interestingly, one of the brands that does reportedly work natively with Homelink is Merlin/Chamberlain. So, you can set a Merlin door to toggle its open/close state as the car approaches or leaves. However, my understanding is that it doesn't read the current position, so if you drive onto your driveway while the door is open, then the garage door will close automatically.You have to do the same with many Aus garage doors anyway as they don't natively support Homelink.
