Thanks , the website was super helpful. I had to change my garage door opener remote settings and it walked me right through it. Homelink now works perfectYou also need to make sure you hold it close to the sensor in the bumper (front left, IIRC).
There are troubleshooting options on the homeland website for many cars and opener models as well.
Had a harder time with my S than either of our M3s.
Another thing to watch out for is having LED bulbs in your opener. Most LED bulbs cause interference with the signal from the remote. If you have LED bulbs in your opener swap them out for LEDs that are specifically designed for garage door openers. Genie sells these kind of bulbs. I had a lot of issues with homelink on my Model 3 for a long time and everything was resolved after I swapped out the old bulbs in my opener.
Not bunk.
You have to buy specific LED's that don't interfere with the opener frequency
But they're ON when you open your door and your car leaves the garage (unless you've waiting 5 minutes or so after opening to leave). Once you're out of your garage, it may not close because the bulbs are on and interfering.
It's also possible some LED bulbs don't have this problem, but some do. Specialty LEDs specifically for garage doors aren't that expensive and are guaranteed to work. I'm glad you don't have this problem, but I'm also glad I bought the right design when I installed LEDs in my garage door openers.
They're over $9 each, and you need two. The generic brand ones are under $3.50 each. So far there has been no scientific information provided, like the output of a spectrum analyzer or anything of that nature. What we do see is companies selling expensive bulbs talking a lot about this problem. I wonder why.
And just think of all of those commercial shops that have moved over to LED lighting fixtures, but somehow aren't experiencing this problem. Or, like I said before, the fact that I have my car programmed to open my door from 50 feet away with no issues whatsoever. And the fact that I can close it while I drive away, too.
Maybe if people were buying counterfeit bulbs from who knows where at this point, and those bulbs had an unbelievably high frequency switch mode supply in them, and the components were a total fire hazard because they were so low quality, then maybe I could believe this. But then you'd have to explain to me why a CFL bulb didn't cause the same exact problem since the RF given off from the plasma is completely unshielded. The guy in the video above is using the exact LED bulbs I am, and I can open and close my doors from very far away with my hand held remote as well as my car. Light on or off. Not a single problem.
If this wasn’t a real problem then I wonder why Chamberlain has a support article about this very problem on their website: https://support.chamberlaingroup.co...-I-use-in-my-garage-door-opener-1484145692747
Which links to an list of LED bulbs from a variety of manufacturers that are compatible with certain openers:
https://www.liftmaster.com/catalogresourcesv3/en-us/shared/files/tucmanuals/led bulb compatibility_011714.pdf
So you believe the video I posted was faked so the creator of the video could make more money?
You believe that hundreds of people reporting this problem are part of a vast LED conspiracy intended to make us all spend $6 more per lightbulb for our door openers?
Here is an article describing the RF interference by some LED bulbs- note the actual interference is caused by the driver, not the LED's themselves. The frequency range is 30-300 mhz which can overlap with some openers.
At no point did I say this.
This is absolute bunk, BTW. The light bulbs aren't on when you're opening your door, and strangely nobody seems to complain that bulbs interfere with closing doors
Nor did I say this. But I would point out that "hundreds" of complaints would represent an extreme minority of garage door openers deployed in the US alone.
Stupid question, but... what happens if you do not see the Homelink icon on your screen to even start the programming process? It is supposed to be in the top left next to the lock/unlock icon, and I do not see it. What am I missing here? I have a Genie Intellicode opener, with a remote, so I don't get why there is no icon there.
OK, thanks for the info Android... that wasn't made clear to me by anyone at Tesla. I have the Standard Plus, which has a "Partial Premium interior"... for a while I wondered what was partial about it, now I know. Seems pretty arbitrary, the kind of features they take out of the lower packages, can't imagine that the Homelink sensor isn't on the car, it's just a blocked menu option.If you don't have the premium interior (used to be called Premium Upgrades Package), then you won't have Homelink.
