Homelink intermittent
Discussion in 'Model S' started by baw, Jul 31, 2017.
Tags:
  1. baw
    baw Member
    Chicago
    I have had my MS for 4 months now. For the past few weeks Homelink only works intermittently. Meaning that it does not always open the garage door on the 1st try. I have to press repeatedly and it will eventually open. This use to work flawlessly. Anybody aware of recent software changes that broke this? Thanks
  2. GregKo
    GregKo Member
    New Jersey
    I have this same issue. Not sure when it began giving me problems though...
  3. IGotEastBay
    IGotEastBay Member
    Bay Area
    I have this issue as well. Sometimes I have to switch driver profiles to get it to work.
  4. dakine1
    dakine1 Member
    phoenix, az
    +1 same issue. Works flawlessly on my wife's audi :(
  5. Austral
    Austral Member
    Even moderators don’t follow forum rules....
    LED bulbs in garage (or neighbor's home) could be the issue. Certain manufacturer bulbs infer with the signal. Also put a larger antenna on your garage door opener drive unit. Worked for me.
  6. msnow
    msnow Active Member
    SoCal
    Happens all the time to many, many people. Lots of threads on this topic. One or all three of the following will fix it:
    1. Full reboot of the main screen (foot on the break, press both scroll wheels and don't let off on all three until you see the Tesla "T" on the screen.
    2. Reset Homelink location.
    3. Remove then re-link Homelink.
  7. baw
    baw Member
    Chicago
    Thanks for this! I will try all 3.
  8. MileHighMotoring
    Parker, CO
    Did that work for you? For 2 years, perfect Homelink behavior. The last 2 weeks have been about 40% success rate. I've rebooted the car, reset the location, but haven't deleted and re-learned yet since that's a bit of a pain. It works SOME times so I know the codes are programmed...
    Anyone else? This has to be a bug in the software. Or is the Homelink not properly grounded or something like that?
  9. cgiGuy
    cgiGuy Active Member
    Sacramento, CA
    There are some threads related to delays in app notifications, so I wouldn't be surprised if this was an over Tesla server issue.
  10. Pinot.Noir
    Pinot.Noir Member
    Livermore, CA
    Mine worked flawlessly since I received the car in March up until today. Had to use my remote to close the garage door this morning.
  11. gjgoody
    gjgoody New Member
    Ours will close everytime if we touch the button, but the "auto close" will work sometimes and then sometimes it will not give us the option. No rhyme or reason!
  12. baw
    baw Member
    Chicago
    I tried 1 & 2. Did not try #3 (remove and then re-link). Behavior is still intermittent.
  13. Hazelwood
    Hazelwood Member
    I've tried all 3 solutions mentioned above. Didn't fix it long term. I'm planning on calling and scheduling service to have them fix it as I'm tired of auto open not working, followed by manually pushing the garage open on the screen 6-10 times to get it to work.
  14. cybergates
    cybergates Member
    So Cal
    i had to remove and reset and reconfigure (option 3) above after 4 months. I will try 1&2 if it happens again. (AP2 S75D)
  15. MileHighMotoring
    Parker, CO
    I know for certain my problems didn't exist prior to getting the last software update.
  16. Cowbell
    Cowbell Member
    Atlanta
    I've noticed that auto close upon departure does not operate unless I manually open the door with Homelink before pulling out of the garage. Homelink auto open upon arrival works flawlessly for me when arriving home. However, I'm not sure I trust Homelink with Summons. I saw a video where a guy standing outside crashes through his closed garage door when using Summons because Homelink failed to open the garage door, and apparently, the car failed to sense or react appropriately to the closed door. Sure would like to understand how that could happen.
  17. boonedocks
    boonedocks Active Member
    Gainesville, GA
    #17 boonedocks, Sep 4, 2017
    0CB863A6-6B2A-4855-A75F-024ED109AEA5.png +3 to the above posts that it has worked flawless for months and recently has been less hit and more miss for auto opening/closing Even in front of the door it has taken several taps of the homelink button to activate the remote.
    Bug report submitted:
  18. brkaus
    brkaus Active Member
    Austin, TX
    I'm staying away from auto-open. Homelink doesn't have an "up" or "down" signal. It just has a "go" signal. So it is very possible for it to get confused. The ultrasonics may not see a partially open door.
    Just not worth the risk to me.
    I've also had problems with regular open. Very inconsistent.
  19. idealsol
    idealsol Member
    Orange County, Ca
    i am still having intermittent Homelink issues
    One thing I've noticed is it tends to fail more often if I I'm leaving or entering garage at a faster speed.
    I posted the following in a previous thread about the "trigger point adjustment" for homelink
    The SC adjusted the "trigger time"
    Per the invoice
    Corrections: Homelink General Diagnosis
    Adjusted trigger time for opening from two seconds to one. Cusotmer: Please advise whether issue is better or worse.
  20. headcase
    headcase Member
    Raleigh, NC
    Yeah, same for me too. Homelink now very inconsistent.
