Hi.
I have 2017 75D. A few months ago, I paid $1,650 to upgrade to MCU2. And I lost my home link function. Before replacing this, I had been using the home link function for nearly 5 years. To explain the situation, I came home after the replacement and tried to open the garage by pressing the home link button as usual. But it didn't open. I thought, maybe the hardware changed, and the profile disappeared, so I programmed it again. Naturally, I successfully finished programming and tried to open the garage door, but surely an animation that unfolds the shape of the antenna, such as sending a signal on the screen, is expressed normally. But the garage door doesn't wriggle. I went to the service center and inquired. Simply put, their conclusion is that there are separate modules that register the garage door opener and modules that actually sending a signal to the receiver to open the door. They said that they did not touch the module that signals to the receiver at all whiles upgrading to MCU2. The reason is that this module is not in MCU2 and is far away from other locations. I couldn't understand what they said, but I had no choice and accept their argument.
In summary, I have been using the home link well for nearly 5 years, but I lost the home link function after replacing it with MCU2. Annoyingly, the registration is successfully completed after dozens of attempts, but the function of sending radio signal seems to be blocked or not working.
Do you have any idea or suggestion?
