As I’ve said, a week into 20.1 and zero issues with homelink. Working as intended everytime. I will be curious to hear if this is the experience of others, as well, but i suspect it should be.
A slightly quicker work around. Begin the creation of another named homelink device. When you get to the point where it asks you to pair the new device click cancel.
It will start working again. However, you will now have to delete the device you just named showing up in the list of devices. Just select delete.
Bonus, but not 100% certain bit here - I seem to recall being in a hurry the last time I needed to close the garage door that I didn't bother to delete the temporary homelink device. When the thing stopped working again I went to create a new temporary device I saw the one from the last time I did this. Instead of creating a new device I deleted the last temporary device. If my memory is correct that also started homelink working again! So you may be able to save yourself some time if you don't delete the temporary device and reserve its deletion until the thing stops working again.
I'm happy to report that since the latter round of firmwares hit, I've not had this problem since. Will continue to monitor, of course, but it's been a good few weeks with no issues.
I'm on the latest I think (2019.20.4.4). Homelink worked PEFECT up until the last couple of updates, both within the last 2 weeks or so. Pretty annoying. It will start to trigger the garage door then quit. :-/
