Homelink on the Roadster
Discussion in 'Roadster 2008-2012' started by simonog, Apr 25, 2015.
Tags:
  1. simonog
    simonog Member
    United Kingdom
    I have been seeing some strange behaviour of Homelink on my newly acquired Roadster (2.5).
    Can anyone tell me whether the car can support rolling code fobs or just static?
  2. jimmyz80
    jimmyz80 Member
    El Dorado Hills, CA
    I have a Liftmaster 3800 that I believe uses rolling codes. Homelink in every car I've owned has been flaky with it. Most of the time a quick press of the button will open the door, and then others I'll have to hold the button for 10sec or so before the opener does its thing.
  3. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    My 1.5 definitely supports rolling codes.
  4. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Homelink supports both fixed and rolling codes, depending on what your garage door wants. When you are "training" it, using the existing opener lets it learn a fixed code. If it can't learn a fixed code, instead you press the training button on the door controller, and it instead learns the car's rolling code. It requires a few consecutive transmissions to do that. Then in future, if the car transmits a code from "the future", it will again require a few consecutive codes to resync. If you press the homelink button while still out of range, you might cause this behavior yourself.
  5. Andrew Wolfe
    Andrew Wolfe Roadster 472 - S 440
    Los Gatos, CA
    Mine too. Brand new LiftMaster from 2 years ago.
  6. rdstr
    rdstr Member
    Richland,WA
    I was surprised my 10 year old Blue Max opener did not sync with the car... it has a fixed code. However, my newer LiftMaster with a rolling code synced up in 10 seconds with the training mode button depressed.
  7. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    If it's a new Homelink opener, you should read this.
  8. m0rph
    m0rph Member
    Belgium
    I bought this universal receiver from Homelink (PR433-4), thinking I could program the car with that. But it looks like both the car and the receiver want to "learn" the transmitter code. :cursing:
    I'm willing to buy a standard Homelink remote if needed, but I'm sure that one also wants to learn a code first. What device initially creates the code? Can someone solve this chicken or egg dilemma for me?
  9. ibcs
    ibcs Member
    Ohio
    I just got a new liftmaster myself and to work with the roadster it requires the home link repeater. It plugs into an outlet and Yukon use the home link remote to program the roadster. Works perfect after that was installed too.
  10. rugbymonk
    rugbymonk Roadster #287; S Sig #14
    NJ
    Hi Anyone!
    For some reason my Homelink stopped working. It’s happened before and I have “retrained” my Tesla Roadster (#287) to learn learn the signal from my universal remote. Now, when I press the retrain (or add) button, the VDS simply says “System preparing - may take up to 25 seconds” and then times out.
    Without fail, I can “delete” and “rename”, but cannot “add” or “retrain” buttons.
    I have tried several times after recharging, open/close chargeport, etc. No luck.
    Any thoughts?
  11. hanknum
    hanknum Member
    Santa Barbara
    Does my 1.5 (#187) have Homelink? If it does, where are the buttons?
    Thanks
  12. ra88it
    ra88it Member
    Southland
    I actively hunted for your 1.5! Take good care of her!
  13. slcasner
    slcasner Active Member
    Sunnyvale, CA
    The Homelink icon appears on most of the different screens that are shown on the VDS. Before you can use it, though, you need to train it using the remote for whatever device you'd like to control.
  14. AEdennis
    AEdennis Active Member
    Yes...
    The VDS is the touchscreen on the left side of the 1.5 Roadster... It can support up to three remotes...
  15. backmost
    backmost Member
    Middletown, NY
    I tried the HomeLink setup on my 1.5 but it doesn't seem to pair with the remote and gets stuck on the point the remote at the VDS screen. My house was built in 2015
  16. ellidz
    ellidz Member
    Los Angeles
    When I set it up it took forever to get it to work. I think the issue was that I needed to flick a switch on the receiver for it to be programmed, despite the receiver unit saying it didn't need it. Also, I think the Roadster is very sensitive to location when it says "vehicle's left speaker."
    However, I did get it working with my 1.5.
  17. Gary1M
    Gary1M Member
    Orange County, CA
    I was able to get the HomeLink on my 1.5 to pair with our original circa 1993 garage door opener and community gate with minimal issues.
    But when I upgraded the garage door opener last year I must have tried a dozen times to get it to pair with HomeLink but ultimately gave up and resigned to use the garage door opener remote.
    The HomeLink still works with the community gate, though.
  18. drewski
    drewski Supporting Member
    SF Bay Area
    I opened the dash to clean out some Alpine wiring and boxes and saw the Homelink unit. It was a VW/Audi part and sat between the left front speaker and instrument cluster, so the directions seem reasonable.
    I don't know if the Solarguard windshield interferes at all, but it did take 3 tries to pair with my opener. My ICE car (an Audi) programmed on first go.
  19. hanknum
    hanknum Member
    Santa Barbara
    Sorry I missed this before...
    I will, is there something special about this one I should know of?
    Thanks
  20. hanknum
    hanknum Member
    Santa Barbara
    For some I had in my mind that the button was on the key, and that I could either have that operate the trunk release or homelink… I don't know where I came up with that. Three remotes is fantastic. I have a gate as well as the garage door. I'll give it a go the w/e.
    Thanks all.
