Hi,
I have a "recent" (~2011) Craftsman 139.53918d garage door opener, and I seem unable to get it to work with Homelink on my new Model X.
I've followed the directions at http://manuals.garagehowto.com/craftsman-manual-139.53918D-[1109396L]-belt.pdf which boil down to:
1. Press and release the "learn" button on the motor unit. The learn LED will glow steadily for 30 seconds.
2. Within 30 seconds,press and hold the button on the hand-held remote*that you wish to operate your garage door.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed,two clicks will be heard.
When I get to the "programming" phase of the homelink setup, I see the garage door light flash immediately in 1-2 seconds, but the Tesla keeps on "programming" for 20 seconds more. Then the "test" never works to open or close the door.
I've also tried switching the homelink transmitter mode from "standard" to "default". When in "default" mode, I see no blinks from either the Tesla's lights when it is learning the signal, nor from the opener when the Tesla is programming.
Back in standard mode, I've tried just putting the opener in "learn" and pressing the homelink button. When I do this, I again see "blink" from the opener, but homelink does not work to open the door.
What am I doing wrong? I've gone through all of this about 10 times, and I just don't see what I'm doing wrong.
It feels very much like the Tesla is just not using the correct rolling code algorithm, and is getting the frequency right, but the code wrong. I've seen stuff on-line for older cars needing a bridge to work with Security+, but surely that cannot apply here..?
Thanks for any hints!
