Nope didn't forget about a stick. There is actually something logical to about how it operates AND it they operate pretty much consistently across most modern cars with few minor differences. Manual gearshifts are typically located in the center console area of most modern vehicles. So very easy to go from a Mustang with a manual to a Camaro with a manual transmission. The clutch operates the same way. The same principles apply. Depress the clutch, engage gear, release clutch until you start to find the friction point, then engage more slowly at that point, so you don't pop the clutch. All these things can be done without looking in very short order as there is standardization across most companies.
The mechanism controls the range of motion and guides you. Imagine if the clutch was free form, with a very small place to actuate it, and you had to depress it within a very narrower range to activate. That would make it needlessly complicated.
Stupid implementation. If you believe the reports of the code changes to support a wheel on the S/X then obviously enough people weren't happy about it that they might actually entertain putting a wheel back in. If that isn't an admission of failure regarding it, I don't know what is. Remains to be seen if they actually follow through. Elon can be very stubborn and double down on stupid decisions too.
If the yoke was the best thing every, why isn't Porsche, Audi, BMW, MB, etc. rushing to drop one in all their cars, or even one model? Why didn't they slap that sucker on the 3/Y if so amazing?
It could be amazing IF they used non-linear steering which according to Elon is years away. So just like the snake oil FSD, we got something similar with the wheel. The ONLY objective advantage is in the current form of the yoke I see is to keep your hands at the 9 & 3 position which has benefits for airbag deployment. That may be offset by people not liking to hold the yoke that way. Not to mention you could hold the normal wheel in that same position anyway.
Again it isn't the yoke itself that I have issue with. It is how they didn't go far enough with what they should have done.
