Hong Kong Meet-Up - Sunday 15th May 2011
Discussion in 'News' started by markwj, May 11, 2011.
Tags:
  1. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    There will be a meet-up in Hong Kong, early on this coming Sunday 15th May. This is for all local Tesla owners and Tesla Club Members. We will be meeting in Tsim Sha Tsui, followed by a group drive (should be lots of roadsters coming) and brunch.
    For further info, please contact Jessie at Tesla HK.
  2. AndrewBissell
    AndrewBissell Member
  3. markwj
    Hong Kong
    Fun.
    10 roadsters and 1 horse (seriously) turned up. I ended up pretty-much circumnavigating Kowloon and the New Territories, putting 180km on the odometer and using about 1/2 the battery. Strange, really, as Jeremy Clarkson said I'd run out after 80km. Seems to work in my world.
    This emphasizes how suitable EVs are for Hong Kong.
    We ended up at the Jockey Club facility in northern Hong Kong, close to the border to China. This is where one of our members keeps his horse. Many comments were made concerning comparisons of horse power, and 0-60 times. Conclusion seemed to be that the horse wins on both torque and turning circle, but loses out on tailpipe emissions.
    The best part of these meetings, for me, is the discussions with other owners. Sharing hints, tricks, problems and recommendations. It is still a small community here, but we all share a passion for the brand we drive, and EVs in general.
  4. doug
    doug Administrator / Head Moderator
    cool! looking forward to some pics.
  5. tetsuos
    tetsuos HK #488 (2.5)
    Hong Kong
    Indeed a good time, but brutally early.
    I'm curious to know how much energy your charge cycle consumed following the trip, Mark. On my 13A charger, I used 52 kWh to fully recharge from ~30 SOC in normal mode. I am averaging about 330 kWh/km plug to wheel using this charger. I have a question to the techs pending about charging efficiency and how much energy I could save if i use either the 32A or 70A charging options...
  6. tetsuos
    Hong Kong
    Standard Mode...
  7. markwj
    Hong Kong
    Yes, painful.
    I actually haven't plugged it in since Saturday night (and it is Tuesday, with a short airport run yesterday as well as two office commutes) - The battery really is big enough for me ;-)
    I'll have a look tomorrow morning after tonight's charge. I charge at 70amp from HPC.
  8. markwj
    Hong Kong
    Here's a group shot (a couple of the cars were parked in a different area, but it shows the group against the fantastic Beas River background).
  9. markwj
    Hong Kong
    Curious: I can't find this screen on my car. I can see charge history, and total consumed (this day, this month), but can't find any consumption history screen.
    I charged last night (29Kwh for 2h18m, 70amp standard mode), but energy use screen says 54Wh used today (this was this morning, when I hadn't used any power since charging). Not sure what it means by 'today' on that screen. Maybe it is based on the trip counter? I guess I'll have to read the manual ;-)
    Probably best to raise your question on this forum, and see if any of the techs here know what is going on. If the disparity is caused by 32A vs 70A and the aircon, then it should use less overall power at 70A (as the aircon is on for less time).
  10. vfx
    vfx Well-Known Member
    CA CA
    Sweet!
    Your 2.0+ ratio to 1.5 is opposite of us in CA.
  11. markwj
    Hong Kong
    There is one white import from UK, but all the others I've seen are new (earliest was late last year). I heard there were 4 new roadsters being delivered here is month (May) - mine was one.
  12. tetsuos
    Hong Kong
    You're correct... There (AFAIK) is no screen that shows consumption in this way. The trip counter is the best source of info, since it records net usage and average consumption per km. I just compare this value (assuming I reset it before heading out after a charge) to the charging history when I get in the car in the morning after charging.
    This morning's calculated average socket to wheel usage was 310 Wh/km. I'm using the 230V 13A spare charger for my daily charging needs.
  13. markwj
    Hong Kong
    I'll charge it tonight, in standard charge mode, then reset trip counter and repeat tomorrow. I should have the 70Amp result for you in a couple of days.
  14. markwj
    Hong Kong
    Ok. Got the figure. It seems the 'today' figure resets when you start driving.
    Today I drove about 44km on my commute. Car says I used 7.4kWh (rounded to .1 kWh). Tonight's recharge was 50minutes at 70Amp, using 8kWh (rounded to 1 kWh). Seems to be about what I would expect. Perhaps I should try it tomorrow at 13Amp?
    P.S. This also puts my commute at about HK$4 each way (about 1/4 the Prius I replaced, and 1/10 the Land Rover the Prius replaced).
  15. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    You might get better information using the car's log. Download it using a memory stick and analyze it using the Tesla Graphical Log Parser. http://www.teslaflux.com
  16. markwj
    Hong Kong
    #16 markwj, May 18, 2011
    The Tesla sales manager is a photographer, and took some nice shots of the drive.
    They are up on Tesla's facebook page now:
    Tesla Motors Facebook - Sunday Drive
  17. tetsuos
    Hong Kong
    Wow... That's much better efficiency than mine. My charge sessions usually last around 6-8 hours at 13A. If you're feeling like being a good test subject, I would find both 13A and 32A values to be quite useful.
    I wonder if Kenneth got any shots of me crossing the double white lines after I followed Philip into the wrong lane of the tunnel... :-/
  18. markwj
    Hong Kong
    10.0kWh usage yesterday took almost 2 hours and 12kWh charge at 32Amp.
  19. tetsuos
    Hong Kong
    This deserves an actual test... Do you mind if I drop by some time to try charging on your HPC? :cool:
  20. markwj
    Hong Kong
    No problem. My rates are good ;-)
    I'm planning to try 13amp tonight.
