Hood River to Kirkland trip for new Model S owner
TeslaSinHR
73
3
Bellevue, WA
Just got my Tesla Model S about two weeks ago and am planning on a weekend trip from Hood RIver, OR to Kirkland, WA and back - 240 miles each way. Leaving Fri 7/19. I've driven to Portland and back a few times already so that doesn't bother me at all. I've been having some weird range anxiety dreams related to running out of juice on the way and the hassles involved (and embarassement factor) of being towed and getting recharged.
It is unclear whether the Centralia Supercharger will be online by then or not - although another member of the PDXTesla group spoke with one of the construction crew who claims that it will be operational Thursday 7/18 but I'm not going to depend on it.
Finally I decided to just make a plan so I can sleep peacefully. Since it is my first time, I actually want to check out some additional charging options as well as the supercharger and I'm going to give myself plenty of extra time to stop and charge in case the supercharger isn't ready or has problems.
Hood River, OR --> Ridgefield, WA (77 miles). J1772 charger, stretch my legs, scope out the place, maybe get some coffee. Charge for about 15 minutes.
Ridgefield --> Centralia (69 miles). If the supercharger is online, I will top off using that. If not, use the Wendy's J1772 while I get lunch. Maybe 30-45 minutes. Hoping the dining option are better than just crappy fast-food. Yelp is my friend.
Possible stop in Lacey at the Dept of Ecology chargers to check that out - it looks like there is a big shopping area nearby with nice restaurants, shops and a movie theater! Might be a good place to stop on the way back as well.
Centralia --> Bellevue Square Tesla (85 miles). Call ahead and try to reserve a spot so I can charge at their HWPC charger while browsing around the mall until my friend gets off work.
Bellevue Square --> Kirkland, WA (5 miles). There are supposedly many free ChargePoint J1772 stations at various locations in downtown Kirkland (City Hall, Marina Park, Public Library). Looks like one is about a 10 minute walk way from my friend's house. Do as much charging at these stations I can over the weekend.
This should give me some confidence and I can make appropriate adjustment for the trip back. Going back I hope to by close to a full, max range charge. If not, I will pop into Bellevue Square Tesla again. I basically intend to make the same stops on the way back as needed and based on my charging experience going up.
Any additional suggestions?
Thanks
deonb
4,057
4,208
Redmond, WA
You have a 85 with twin chargers and 19" wheels, right?
If so, you have a few options.
1) Range charge 90 minutes before departure. Switch climate control on range, put cruise control at speed limit (except do 65mph in the 70mph zone), and drive all the way to Kirkland. (Assuming no bad weather, which looks fine on the 19th). Keep your wh/m under 320 and you'll be fine. If it goes up, slow down by 5mph until it's below 320 again. This will by far be your fastest option, except for Supercharging. If the SuperCharger happens to be in operation, charge up and drive any speed you want the rest of the way.
2) If the Centralia SuperCharger isn't in operation yet, contact 12v to v12 from this thread:
http://www.teslamotorsclub.com/show...A-Burgerville-Model-S-to-Roadster-HPC-adapter
and see if you can get in on the Centralia Roadster charger. Stop for 30 minutes for lunch at Burgerville, and pick up 30 miles of charge.
Your contingency stops are great & necessary to have in your back pocket, but that trip is doable by just watching your speed. 320 on the I5 in WA is easy to achieve, provided that you use cruise control. My lifetime average is over 400 wh/m at 4000 miles but I still get at or below 310 on the I5 on a nice sunny day @ speed limit - and that's with 21" wheels.
PhilBa
1,382
68
Seattle
The ribbon cutting ceremony at Burlington on Tuesday is for Centrailia as well. If Centralia isn't up by then, it can't be more than a couple of days.
@deon - 400 w/m, you're havin' fun!
TeslaSinHR
73
3
Bellevue, WA
Yes, I have twin chargers and 19" wheels.
deonb: Thanks for the tips on extending the range. I'll try to follow the advice - although it will be tough to put the already anemic air-conditioningl in range mode. I had a gut feeling that driving slower so you don't have to stop for slow charging would be an overall net gain in time. Where does it show your lifetime average? I've only noticed the averages for Trip A and Trip B.
drbradfo: I have fobs for Aerovironment and ChargePoint. I have also signed up for Blink Plus - they no longer charge an annual membership according to the customer rep I spoke to.
Puyallup Bill
605
2
Puyallup WA
Sounds like a nice trip - have fun. Of course, if the Centralia SC is up and running, all this discussion is academic - pedal to the metal, as they say.
Otherwise, I wonder about the value of such short J1772 stops. Most around these parts will only deliver about 20 MPH. Also, counting on Bellevue Square can be dicey. Both times I tried, everything was in use or otherwise blocked, and I am quite sure it is first come, first served. The staff is helpful in moving things around, if possible. There are J1772s right near the Tesla spot on the same level.
Of course, do carry your UMC as I believe all Tesla locations have a 14-50 outlet, and that beats a J1772.
stevezzzz
R;SigS;P85D;SigX;S90D;XP100D;3LR;YLR
Nov 13, 2009
6,100
121
Colorado
The slower your charge rate at the next intermediate charge stop, the slower you'll want to drive. The bottom line is the total time (driving plus charging) needed to reach your desired state of charge at the next stop...unless it's an overnight stop. Try not to let your average consumption while driving exceed the charge rate at your next stop: much higher and you increase your total time because even though you get to the charger sooner, you'll spend a lot more time charging than you saved driving. Admittedly, it's not easy to drive slow enough when your next charger is a 30A (6kW) J1772.
Many people reserve Trip B for their lifetime statistics.
deonb
4,057
4,208
Redmond, WA
Do you have passengers in the back seats? Maybe then it will be an issue. If not, check your vent directions.
If after that it's still not cold enough in the Pacific North West, take your car in for service to have it checked out. I'm a big guy and I never get cold - I wear shorts in the middle of winter and sleep with an A/C on all year around. However, the A/C on my Model S at the LOW setting is uncomfortably cold for me - even in range mode while it's > 90 outside.
Range mode actually just change how quickly it gets cold/hot. It doesn't change how overall cold it gets. Especially if you pre-condition the car using the app while it's plugged in, there shouldn't be a difference in comfort between range and standard.
I've never reset Trip B, so that is my lifetime average.
TeslaSinHR
73
3
Bellevue, WA
What I find with the "anemic" A/C is that if set I set it to 73 and it doesn't get cool enough. I have to crank it down to 70 or lower to be comfortable. I feel like the actual number on the A/C setting isn't really a target temperature. I keep my house at 74 and it is plenty comfortable and every other car I've owned with temperature settings on the A/C didn't have this problem.
Maybe something is wrong with my inside temperature sensor?
Good tip on keeping Trip B as my lifetime average - although all the demos of the speed and acceleration I'm giving to friends and neighbors is messing with that :)
deonb
4,057
4,208
Redmond, WA
Why is it specifically important to you what the actual setting value is? Interior temperatures in a vehicle is incredibly localized, and depending on where the thermometer is located it can be off by 10's of degrees.
That's the reason why most cars don't prominently display a interior temperature reading - customers will be in the shop twice a month comparing a reading from a Fluke somewhere in the car to whatever the car's reading is and complaining it's wrong.
Just find a value you like and set it to it. It's not going to be an actual accurate value - not on any car. If you however find you need a value below 'LOW' then it's of course a different story.
TeslaSinHR
73
3
Bellevue, WA
Just previous experience with other cars (Audi, Prius) where a setting of 73 to 75 was quite comfortable and they were good at maintaining interior comfort. But it is fine, 70 seems the sweet spot for me in the Tesla.
PhilBa
1,382
68
Seattle
yes, the Prius has excellent temp regulation.
FWIW, I don't think the MS has bad temp regulation. For me the issue is the fan is controlled by the temp when on auto. I'm forever pushing the fan speed up. Once it gets it to about 5, I'm comfortable. And while I'm at it, I hate the fan slider. They need a way, especially while you are driving, to kick the fan up/down by 1.
TeslaSinHR
73
3
Bellevue, WA
Plus I think Audi and Toyota and other big car makers have decades of experience figuring out and optimizing cabin climate control. Hopefully Tesla can just download new climate control firmware when they see fit to address this. It would be cool (no pun intended) if they partnered with Nest to figure this out.
TeslaSinHR
73
3
Bellevue, WA
Just a followup. With the Centralia Supercharger going live the day before my trip, it was a no-brainer. I ripped along from Hood River to Centralia (150 miles). Had 83 miles (~30%) left on the battery and it charged at a peak rate of 292 mi /hr !!!! Charged for about 40 minutes while doing some outlet shopping. Then 100 miles to Kirkland. I did a few hours at the free charger at Kirkland City Hall but otherwise charged on my friend's 110 v outlet. For the limited driving I did while in the Seattle area I was fulled charged by the time I left to return home on Sunday.
It was surprising to me how often the charging stations in Kirkland were occupied by other EVs - Leafs and Teslas. I downloaded and learned to use the ChargePoint app on my phone which tells me which stations in their network are being used so I don't waste time.
