Butane
Yea, I'm always hesitant to just change to a larger breaker, however it was a 30A outlet with a 20amp breaker, not sure this would have ever been to code in the last 50 years?.... I thought it should be a 30amp breaker as the wire is 10/3 and I was replacing a 10-3 outlet. When we had the panel redone, maybe the guy put in the wrong one, or maybe thats what was there before so he just coppied it.... I imagine it's one continuous run as there is no reason for it to not be, but can't see much in the crawl space due to ducting, insulation etc. Yea the ground wire (4th wire) was in the cable, just not connected to anything, or run into the box (had to pull off some drywall to find it).
Sounds like I should be good to go, so long as the run isn't over 100 feet? It's from one side of the house to the other but we don't have a large home, 1400 sqft...
One more thing, I'm reading that in a crawl space (non permanent stairs or ladder) you can simply run romex, but it has to be 6' away from the entrance hole. This would not be possible as you can't really get to 6 feet away as you can only crawl down the center. Guess that means I'm stuck with THHN and a separate conduit (we have a metal one already but it's for the solar Inverters that backfeed into the panel).
I want to save some cash, but I also like everything to be to code and not burn my house down.
Not familiar with that rule on crawlspaces. I know you are supposed to protect them in attics under certain conditions, and generally a couple pieces of wood, taller than the cable, nailed on either side meets the requirement. I don't think you'll have any issues running cable in a manner similar to what is already down there. I can be worth calling your county/city inspections office. Out in my area, they're pretty friendly and happy to answer questions like this. Even if they force you into a permit, it can still be cheaper to get a DIY permit instead of hiring an electrician.
