My TMC post is not a DIY, but just a note about placement... Yours is where most have been placing it and it looks great. You can't see it from the interior and even the exterior is camouflaged from the rear view mirror. The ONLY reason I could see mounting it where I chose to mount it was in case you wanted to have fun (as you can see Brianman made me post a few posts later) and video the passengers (for instance during test rides), then my mounting will allow and this mounting will not. Just adding it to the knowledge base is all. Not saying its superior or inferior.Interior:
Driver side:
Pax Side:
Exterior:
OnlyI just picked up a BlackVue DR500GW-HD. For now I am just using the cigarette plug, but the camera shuts down when I get out of the car.
I routed the wire temporarily from the camera (behind the rear view mirror) over the visor to the door frame at the top of the A-Pillar.
From there I tucked it into the soft gasket around the door frame and down to the bottom of the b-pillar. to keep it out of sight I then put it loosely under the passenger seat to the center arm rest (where it can plug into the cigarette lighter).
Plenty of cable for a more secure mount.
I found a wire kit at Best Buy. the price was ridiculous, but I got it anyway. the wire is pretty long but included the fuse holder.
the male plug that plugs into the "spare" 12V plug over the rear view mirror was only 50 cents (I got 2, shown in picuture) at my local electronics Supply store. (not Radio Shack, I looked there and they were useless)
I now have two steps to complete my cord.
1. cut the end off the connector and solder the wire to my male plug.
2. (optional) shorten the wire between the camera plug and the fuse holder.(seems like a waste to cut the wire, I guess I could just tuck it in:redface
Only
Thing that sucks is the camera gets hotttttt
Yes it does, but it still works. The 16GB SD card that comes with it is not the best quality, it appears to be affected by the heat ("check SD card" comes up often) powering it off and on is a quick temporary fix... I bought a 32GB card that seems far more reliable.
As far as the cable, I bought a spare on Amazon for $20, then bought the 5X20 fuse holder/2A fuses at DigiKey and built the cable that uses the spare connector in the microphone spot, and wired it up... Power is on all the time from that spot, and the cable is completely hidden
Check out LuxuryBlack.com. They are the largest US distributor of BlackVue cameras. This is where I bought mine from and they had the best price at the time. They also sell through eBay, but you can order on their website.Also, anyone have a link to someone selling the connector to plug into the 12V?
Go to BlackVue DR500GW-HD WiFi - Custom Firmware - ÑÑ‚Ñ€. 1 - BlackVue DR500GW-HD WiFi - in English - Car-DVR Info - Page 1 where they have a link to the custom firmware and online help. You will need to register at the site to download it.Any link to custom firmware?
My first recording is from 2013/05/04. Mine was hardwired roughly a week after that. No issues observed so far relative to battery drain.If the overhead 12v connection is always on you do get this great feature, but are there any concerns you have for battery drainage?
I have a 14xxx series VIN... Can anyone confirm if the unused wire in the Mic Panel is still there? I opened the panel where the mic resides and I can't find the unused cable that everyone is tapping into. I tried reaching toward the windshield but can't feel anything as far as a unused wire harness.
Thanks!
