How about a pop-up when signaling?
Discussion in 'Model 3' started by insaneoctane, Aug 14, 2018.
  1. insaneoctane
    insaneoctane Active Member
    Southern California
    For such a "safe" car, I think Tesla is under-performing in their presentation of data department. Hopefully v9 will help here, but wouldn't it be easy enough for them to have a pop-up next to the image of your car with the rear-camera super-imposed any time you signal? Below is an example of a pop-up if you signaled left. (Ignore the full-screen rear camera image, most people don't drive this way...I left it in for context so you can see where my pop-up image came from)
    Or even just the whole image:
    • Like x 7
  2. mekberg
    mekberg Member
    Madison, Wisconsin
    But why? If you adjust your mirrors to the SAE standard you only need to glance in the direction of your intended travel.
    In your example I would be looking the opposite of that.
    • Disagree x 1
  3. Boourns
    Boourns Active Member
    Dallas
    Blind spot monitoring is coming to v9, so you'll see the "ghost cars" in your blind spot that you now see in front of you. My guess is that if you turn on your signal the ghost car might light up or something to catch your eye.
  4. insaneoctane
    Southern California
    My mirrors are adjusted correctly. Nonetheless, the Model 3 has limited visibility due to high rear-deck height, small side mirrors and small rear-view mirror. I feel it's adequate, but I'm looking for more than adequate. Don't forget that not every driver is as competent as the best and some can you extra help. When you have all the tech on-board to offer help, why not? Why wouldn't you want to help EVERY Model 3 driver out as much as possible? You pay your insurance rate based off not only your record, but the statistics of EVERY model 3 driver.
  5. woodisgood
    woodisgood It's walnut, beech
    San Francisco
    I’m really looking forward to their implementation of blind spot monitoring. It seems like they have the ability to do so much, so they should be able to come with something that is functional and elegant. Saying it’s not necessary on an otherwise tech’d out car is a total cop-out considering it’s now industry-wide standard in various forms.
    My understanding is that the side cams are B&W, so simply broadcasting their feed to the screen might fall short in the aesthetics department. But even a reliable (meaning not fading in and out) ghost car on screen would be something.
  6. RayW
    RayW Joy Riding
    Cypress
    One of the great mysteries of Tesla -- why no blind spot alerts, like nearly every other new car costing over $20K
  7. scottm
    scottm Version 9 software sufferer
    Canada
    Ya, this is pretty much a no-brainer to add a video pop-up when signal stalk is engaged, or has been tapped.. on any Tesla car
    The rear view camera has enough fisheye to add some value in seeing what's to the sides
  8. Twiglett
    Twiglett Single pedal driver
    Austin
    Why restrict it to the rear view camera when the car has two cameras specifically facing backwards as well as two side view cameras.
    These should have been part of EAP a long time ago.
  9. bsf29
    bsf29 Member
    Raleigh, NC
    According to the ordering page EAP only gives you access to 4 cameras. FSD gives you access to all 8. But it would be interesting if EAP will temporarily use 1 or both of the side cameras when the full automatic lane change is enabled. The current lane change just uses the ultrasonic sensors to detect if a car is adjacent to you and not automatically change lanes. I'm just not willing to test what happens if a car is close behind or beside me. I know the lane change doesn't want to switch when a car is not far enough ahead in the next lane, depending on your following distance setting and how fast the car is pulling away.
  10. woodisgood
    San Francisco
    I missed this. Can you link it?
  11. xpitxbullx
    xpitxbullx Member
    Las Vegas
    Yeah. I never heard that EAP would only ever have access to 4 cameras. Also, even with FSD option , none of the Model 3’s even use those cameras, yet.
  12. eli_
    eli_ Member
    Bellevue, WA
    I'm assuming that the autopilot visualization will eventually start to show cars in the blind spot. Initially it only showed cars directly in front, now it shows cars in adjacent lanes in front of you, next logical step is to show cars 360 degrees around you. Maybe flash them or make a noise if you activate your turn signal and they're in your blind spot.
  13. bsf29
    bsf29 Member
    Raleigh, NC
    It's the information Elon said when they announced the MS Refresh and were releasing AP 2.0. Just go to the Tesla page and design a S or X. 3's design page is lacking too much information. They probably assume that buyers have also priced a MS/MX and know the information. Order a Model S
    It's why people feel that EAP/FSD are overpriced. The hardware comes with every car and it is just paying a premium to enable the feature. At least now existing FSD will be upgraded to the new MCU they are developing, so it seems like you are getting something for the additional cost. But once the new MCU is ready, all cars will be built with that hardware. Just my guess with what happened with AP 2.5.
    I think all of the front and the rear are now actively being used if you have at least EAP. From other posts, the side have been in shadow mode for awhile (I don't remember which post had that info). Actually I think Tesla has every car's camera running in shadow mode to collect data for their simulations. But I noticed that our cars are uploading much less data after each drive.
  14. woodisgood
    San Francisco
    Interesting - I had never looked at the S order page in-depth. It does have more information.
  15. xpitxbullx
    xpitxbullx Member
    Las Vegas
    I was under the impression that out of all of the cameras, the Model 3 right now only uses the front camera locates in the rear view mirror and the back up camera. What other 2 are they using now? The delivery lady said the 2 in the front quarter panels will be used in the future.
  16. SageBrush
    SageBrush 2020: Drain the Sewer
    New Mexico
    NO, thanks
  17. gtmotor
    gtmotor Member
    Arizona
    Agree. Too much information is bad. I found the video pop up feature to be incredibly annoying on a Honda I drove recently.
    I love the idea of showing the "ghost" cars 360 degrees around the car and having them flash and/or make a noise if you turn a signal on or start to veer into that lane.
    • Disagree x 2
  18. Need
    Need Active Member
    SoCal
    I would rather the blind spot warning on the side mirror like all other cars. It is the one place that you have to look anyway, so putting it there seems logical. BTW OP, in your example, the car you showed should have been on the passenger side, not the driver side. In order to super-impose the rear view camera image, the image has to be flipped and put on the other side mirror.
    BTW, does the Model 3 screen shows cars in blind spots with radar like arcs on the image? My model X does that. Wouldn't that be enough without the actual image of the car? I still would prefer an amber light on the side mirror.
  19. rhaekar
    rhaekar Member
    San Diego
    Or they could just make sure the rear view camera screen pops up when you signal if you didn't have it open already. I usually drive with it on.
  20. xpitxbullx
    xpitxbullx Member
    Las Vegas
    What would be nice is if the had a ‘jackoff alert’. You look in your blind spots, all is clear. You don’t see the JO flying 30 mph over the speed limit coming from behind in the lane you are merging into.
    Come on, Tesla. Jackoff Alert!
