How bad does my HPWC wish I had dual chargers?
Discussion in 'North America' started by C.r. Moorehead, Dec 8, 2014.
  1. C.r. Moorehead
    Las Vegas
    It's ALL about the voltage baby! Now, if I can just stumble upon a dual charger from Santa! LOL Maybe if it wasn't over 3000$ - Hey Elon - get reasonable with dual charger upgrades!!! $3600??? That box that is made in house CAN'T cost more than $350 to build!!! I know it's diamond season - but....LOL
  2. Mnlevin
    Mnlevin Member
    South Florida
    And why did you buy a HPWC without having dual chargers? Did you like the way it looked? The cost of install was probably more than a standard 15-50 240v outlet. Seems like you didn't have all the right information.
  3. MartinAustin
    MartinAustin I Do Not Read Electrek
    Austin, Texas USA
    Do you have 80A of current available to the HPWC? If so, yeah, it's a bit of a waste. I can see only giving it 40A if it was inordinately expensive to supply 80A (which in the USA requires a 100A circuit... thick cables etc.)
  4. jerry33
    Texas
    Unless you're running out of time to charge at night (e.g. you run past TOU times, or you don't get fully charged by the time you leave), the only thing you gain with twin chargers at home is a bit of efficiency gain at the higher amperage (it's only below 32 amps that the inefficiencies really start to show). The reason for the high price for installing later is to encourage you to purchase twin charges with the car. That saves the them the time it takes to install later (even though they get paid for it, it means there's something else they couldn't do at the Service Centre).
  5. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Well you could get some use by listing on PlugShare so other Tesla owners can charge at a reasonable rate. ;)
  6. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Maybe that's true now, but the prices were set that way from the beginning when as has been confirmed here numerous times, many Tesla staff were actually discouraging people from ordering dual chargers, not encouraging it, unless they were buying HPWC.
  7. RandyS
    RandyS Fan of Elon
    San Diego
    I bought the twin chargers for road trips (and have used them several times), as well as a HPWC for the garage. The main reason for the HPWC is that I don't think the Mobile Connector is engineered to be used day in and day out for a permanent home charging solution. It may be better now with the adapter redesigns, etc. but I'm glad I made that decision after seeing what has happened in other situations. I carry my Mobile Connector in the trunk for when I need it, and use my wall-mounted HPWC for home charging...Works out great, and I don't have to worry about over heated or melted connectors on the Mobile Connector....
  8. tom66
    tom66 Member
    United Kingdom
    Uh... it's a 10kW AC-DC isolated, regulated, automotive rated power supply. $3,000 is actually cheap for one of those.
  9. tga
    tga Supporting Member
    New Hampshire
    For comparison, in the EV conversion world, you have:
    • Manzanita Micro PFC40 (40A charger for an EV conversion), >$3k
    • EMotorWerks SmartCharge 12000 (12kW) - $2000-$2300 assembled, $1300 kit
    These are parts only, without installation, so Tesla's price probably reasonable.
  10. Cottonwood
    Colorado
    Yes, but given that the option price when you order a car is $1,500, I find it hard to believe that there is $2,100 in labor and changed configuration to add the second charging module. I hope that Tesla lowers this price to a more reasonable point, like they have the HPWC and the mythical CHAdeMO adapter.
  11. freds
    freds Member
    Bothell, WA
    Well the HWPC has a more heavy duty cable; so I guess you are just getting more exercise for little benefit....
  12. Twiglett
    Twiglett Single pedal driver
    Austin
    a cynic would say its easier to reduce the price of something if you never ship it :)
  13. PlanB
    PlanB Banned
    Oregon
    $500 seems like a more reasonable price for HPWC.....$750 is still pretty high.
  14. Benjamin Brooks
    San Jose, California, United States
    For an 80A EVSE? What other companies sell J1772 80A EVSEs for less than $750?
  15. markb1
    markb1 Active Member
    San Diego, CA
    They're all ripoffs. EVSEs are just glorified extension cords. Maybe Monoprice needs to step in and shake things up.
  16. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    Maybe no one has because they really are not all ripoffs. Maybe when you make and sell "glorified extension cords" you need adequate research, testing and certficiation to ensure quality and even after that you need expensive insurance, which all factor into the price beyond taking one apart and adding up the price of the parts.
  17. AoneOne
    AoneOne Member
    Fox Chapel (Pittsburgh), PA
    I saw a report that replacing a bad charger cost an out-of-warranty owner $3300, so they're pretty consistent. The chargers are located under the rear seats, so it could be quite a bit of work to install one after the fact.
  18. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    And the liquid cooling loops!
  19. C.r. Moorehead
    Las Vegas
    Although I'm not positive - I believe that the coolant loops run in series with the current single charger. Would like some information regarding that if anyone knows. Also - I just swapped out the Nema 14-50 for a HPWC - there are a bunch of them brand new from Canada for 500$ ish on Ebay (cheaper and way more durable than the Mobile charger) and it comes with a great hanger for the cord and just so happens to clicks in like a supercharger. I did have 3 gauge wire to the original nema 14-50 and it's only 12' from main 400 amp service panel. I LOVE that the mobile charger is like it is designed and in the car for an unexpected emergency.
    I would recommend the charger for anyone that has the simple ability to install it. It truly is simple. Truth be told - I haven't changed the breaker yet as it is only 50 amp. LOL but it looks cool on the screen. The dip switches tell the car what current is avail - The breaker is only 35$ and after calling myself out -I will probably click buy it on Amazon. LOL I did post it on Plugshare, but Being in Vegas near a TON of free jc1772 chargers and only 6 miles from a Supercharger - doesn't get me much action! Although before I had it - I did save a dudes butt! He rolled into my driveway with zero on the dash - on the way to the supercharger and a concert downtown.
    Happy Holidays -
    AJ
  20. Chickenlittle
    Chickenlittle Active Member
    Virginia
    If your 3 wires are 6 gauge becareful not to attempt 70 amp charging (assuming you have double chargers. That would require not only larger amp breaker but also 4 gauge wire
