So my car was in a wreck, it's been nearly four months now and I got it back once but there were slews of issues so I brought it back to the (tesla approved) shop to hopefully get everything right the second time around. One issue that it had was the steering wheel was WAY off! Like 15 or 20 degrees cocked to the left. The car didn't pull, it was aligned well, but you had to turn the wheel about 20 degrees to the left to make the thing go straight. It seemed to summon just fine, so the car clearly knew which way the wheels really were facing.
I searched for it online, and spoke with the tech at the shop, and I'm of the understanding now that it's possibly a software calibration to get this fixed? Back when I used to work on my cars, you could only get the steering this far off center by taking the wheel off the column and putting it back a number of splines off. According to the tech, the steering box can re-index itself via software somehow.
I guess two questions, for one is this true that the steering wheel center can be adjusted by software? And if yes, how does it physically work? It's not drive by wire, so I don't understand how it might reindex itself. My car didn't have to have any suspension components replaced at all, but the wheel and tire were because they got nicked, so I don't even quite understand how it could have gotten adjusted so far off.
2017 Model X by the way, though I assume they all have the same steering components
