How can you keep your iTunes library "synced" to your USB Stick?
Discussion in 'Model S: User Interface' started by Argelius, Oct 27, 2013.
  1. Argelius
    Argelius Member
    Palm Springs, CA
    I've copied my entire iTunes library to a 128GB USB stick which I use in the car. While I remain disappointed/dismayed there's no iPod integration with this techno car, I've found the USB drive works pretty well, only missing playlists and the ability to shuffle songs.
    Anyway, is there a way to keep the USB drive in "sync" with iTunes?
    What I'd like to be able to do is periodically take the USB drive from the car and plug it into my computer to have any new music I might have purchased be copied to USB drive.
    I know in Finder I can recopy the entire iTunes library to the USB drive and then select the "do not overwrite" dialog when it starts trying to copy an existing file from the Mac to the drive.
    However, I assume if I have a folder in iTunes called, for instance, "Elton John" which has a new subfolder with a new Album name "Diving Board", that new Folder/Album will not be copied without recopying all the other subfolders within the top-level folder?
    Hope that makes sense. I'm just trying to figure out when I purchase new music in iTunes if there'a an easier way to update the USB drive than merely remembering what the new music is and copying that individually.
  2. boerlin
    boerlin Member
    Switzerland
    Try CCC, Carbon Copy Cloner. A tiny but very useful tool to backup or sync entire HD or folders.
  3. ggbjr
    ggbjr Member
    NC
    +1 this is a great solution. No frills but gets the job done
  4. Mayhemm
    Mayhemm Model S P85+ "Lola"
    Saskatchewan, Canada
    ...unless you're not using a Mac. Then you can f*@% off. :tongue:
    • Funny x 2
  5. N4HHE
    N4HHE Member
    Madison, AL
    A bit of study of the rsync command might be in order. This is a very common and popular Unix utility. Command line. Am certain its available for Windows too but its included on Mac. Or maybe I got it in Xcode?
  6. ggbjr
    ggbjr Member
    NC
    There are still people who don't use Mac? ;)
  7. Mayhemm
    One or two die-hard holdouts.
    Macs don't like the cold up here.
  8. swaltner
    swaltner Active Member
    Kansas, USA
    As mentioned above, rsync is a good option for doing directory syncs like this. On a Mac, you would use a command like
    rsync --archive --verbose ~/Music/iTunes/iTunes\ Music/ /Volumes/USB/iTunes\ Music
    Substitute USB with whatever your USB volume is named. Once you've got the syntax working like you want, you may want to add a "--delete" right after the --verbose so any files you delete out of your iTunes library also get removed from the flash drive.
    A similar command line would work on Windows if you installed rsync. For Windows, another option is robocopy. This is part of Microsoft's Windows Resource Kit that is a free download. It can do a similar "sync only the changes" process that is implemented by rsync.
  9. mknox
    mknox Well-Known Member
    Toronto, ON
    I really tried to like the Mac, but just couldn't. Spent 6 months or so with a MacBook and that was it. Happy with my iPhone and iPad, but it's Windows on the desktop for me.
  10. nrcooled
    nrcooled P#8946 VIN 03225
    NoVA
    I was going to suggest the exact same thing. Forget loading another application when you can just use the terminal/command line to copy new files within a directory.
  11. AnOutsider
    AnOutsider S532 # XS27
    I am not home, so I can't get the name of it, but my Audis have SD card slots, so I used an app that would recognize a specific SD card when inserted, then sync the iTunes folders or playlists that you specify. It's what I use on my USB stick now in the Model S -- insert it, and it syncs just like it's an iPod. On windows it ran in the system try and popped up when you inserted the configured media.
  12. N4HHE
    N4HHE Member
    Madison, AL
    Get the parameters to your liking and save in a text file with #!/bin/sh as the first line and name the file with .command suffix. Now its double-clickable in Finder.
  13. AnOutsider
    The software I use is called iTunes Agent, and it looks like in '11 it got renamed to notpod: Notpod - Portable entertainment manager
    here's another software, though it's a tad more limited. iTunes Sync Binary Fortress Software
  14. coolspot
    coolspot New Member
    Toronto, ON
    I use DoubleTwist - it's used to sync Android devices with iTunes, but it will detect a USB drive/SD card as a destination as well.
  15. NeedToDrive
    NeedToDrive Member
    El Segundo, Calif.
    Another option - for the mac - is Chronosync. Very powerful and can be set to sync whenever the drive is detected.
  16. Drive4711
    Drive4711 New Member
    Netherlands
    Okay, it's a very old thread, but here's a solution for someone who's searching for.
    see http://www.isyncer.de/en
    works for windows and mac os.
  17. jxb27
    jxb27 New Member
    Prague
    You can use FlashTunes, which is available in the app store. It'll keep track of what is on the device and sync stuff over intelligently.
