AMPd
Gas anxiety is low because they are used to it.
If the tables were turned, and people were used to electric cars, and suddenly someone invented a gasoline powered car, the anxiety could be caused when they learned:
You need to add 20 gallons or so of highly flamable combustion fluid every couple hundred miles.
The gasoline will polute the air and cause thousands of people to get sick more often and die earlier.
It will produce Carbon Dioxide that will kill you in just a few minutes if you forget to open the garage door when it is running.
It will need 5 quarts of motor oil disposed of twice a year (25 times over the life of the car). Do not get the contaminated motor oil on your skin as it is cancer causing.
You cannot just throw the used oil away or you will be fined.
The fuel will cost 3X what you are used to paying for electric miles.
If everybody changes to the fuel cars the cities will become so polluted that breathing will be uncomfortable and difficult.
The gasoline is extremely flamable, and thousands of people will be burned to death every year.
If it leaks and catches fire in your garage your whole house may burn down.
The fuel will be heavily taxed.
Most of the fuel stock will come from foreign nations, damaging your countrys balance of trade and draining its treasury.
The fuel gauges will be very inaccurate. The first 1/4 tank will last for a long time, but when it gets down to the final 1/4 is will last far fewer miles.
The fuel will not be renewable. When it runs out all those cars will grind to a halt.
Instead of one smooth transmission you will need up to 10 gear changes every time you go from start to cruise. When you drop into drive or reverse your whole car will shake with a thunk.
One foot driving will be a thing of the past. You need to move your foot back and forth between the gas pedal and the brake every time you wish to go faster or slower.
No more autopilot. Not even a moments rest, even on the longest, most boring trips.
Bet people would have some anxiety then. The anxiety is caused more by fear of change than actual driving factors.
A lot of those a just simple BS or exaggerations
But that’s none of my business
