How come the regen doesn't get to the "limit" line?
Discussion in 'Model S: Driving Dynamics' started by ljwobker, Feb 14, 2015.
  1. ljwobker
    ljwobker Geek.
    Raleigh, NC
    Everyone already knows that the dashed yellow line comes on whenever the regen for the car is limited. However, in my case the dashed yellow line might be at 30 or 40 KW, but when you can see the yellow line, the green regen bar never actually gets to that threshold....
    this doesn't make any sense to me... does anyone know **why** the green regen bar never actually gets to the dotted yellow line? It seems sensible that the yellow line would be the actual limit and as the car warmed up or the battery stays charged decreased the region would line up exactly with where that line was drawn, and the line would creep from the limit back to a full sixty-ish KW of regen...
    thoughts?
  2. jerry33
    Texas
    My guess would be to insure that the bars never cross the yellow line, even if there is some data noise. I can just see the complaints (with photos) about battery degradation because the yellow line is surpassed.
  3. pgiralt
    pgiralt Supporting Member
    Cary, NC
    I've wondered the same thing. Also, after the yellow line disappears, it takes some time before you can actually get all the way to 60kW regen.
  4. rlang59
    rlang59 Member
    US
    I had a brand new loaner last week and regen actually got to the limit line on it.
  5. Evbwcaer
    Evbwcaer Member
    Minnesota
    My car started going to the limit line on occasion after 6.1. In most cases it does not go to the limit line and I often get no re-gen under coasting when the limit line is close to the baseline.
    One thought I have is (just pulling numbers out of thin air) is that the battery heater might be using 5kw and so 5kw of regen, when available, is being used to power the battery heater, rather than going back into the battery and that is why you see a difference between the lines.
  6. NOLA_Mike
    NOLA_Mike Irritable
    Hammond, LA
    Mine regularly goes to the yellow dashed line (when the yellow line is there indicating a limit). Having said that, there is also a short period of time after the yellow line disappears from the display when the regen will still only go to where the yellow line was (a phantom limit if you will).
  7. denverdan74
    denverdan74 Member
    Denver, CO
    Are you running with Range Mode on or off? On - I've seen this behavior. Off - Regen is typically always maxed based on speed of course.
  8. mknox
    mknox Well-Known Member
    Toronto, ON
    Mine has worked that way on every flavor of firmware for almost two years now. Never quite gets to the line.
  9. NOLA_Mike
    NOLA_Mike Irritable
    Hammond, LA
    Hmmm... Since Tesla sent the Torque Sleep Firmware I've been driving with Range Mode ON. Prior to this I had never turned Range Mode On. So, I'm not sure if I've noticed different behavior depending on whether Range Mode is ON or OFF - and my statement about hitting the dashed yellow regen limiter line was made based on seeing it hit numerous times in the last couple of weeks - with Range Mode ON.
    Mike
  10. reddy
    reddy Member
    Amarillo, TX
    I have always assumed that the line limited the amount of power that the regen would produce, but the display showed what was actually being returned to the battery.
    Particularly when we have a lot of demand for heating , the gap is really wide since Battery Regen = (Motor Regen minus electrical load) , the difference being the heating and electronics.
  11. ljwobker
    ljwobker Geek.
    Raleigh, NC
    I don't *think* it's related to temperature, because at the moment I'm living in the Bay Area where for weeks at a time the ambient temperature is never below 50F or above 75F... and my car at least has behaved this way since I took delivery. It seems not to matter what the cause of the limit is -- high SoC, low temperature, etc... I've *never* seen my green regen bar get to the dotted line. In mine it basically tracks to about half of what the dotted yellow says I can get.
    And there is definitely a phantom limit effect in mine as well - once the dotted line disappears it still takes a few miles/minutes before the regen gets to the full 60kWh.
  12. scaesare
    scaesare Well-Known Member
    NoVA
    #12 scaesare, Feb 16, 2015
    The limit lines have always been a little flakey. Then regent limit line always has a little margin below it as described here... and it often disappears when there's obviously still a limit in effect. Sometimes it will disappear for a bit then return. I've wondered if there's a little hysteresis built in to prevent overshoot.
    The power limiting lines also exhibit some weirdness. They aren't always present when the car is power limited... and when you floor it they'll appear momentarily within the swept area of the power meter... so they aren't quite limiting at the level they indicate. Then they'll disappear as the power needle swings back down. I believe this is because of instantaneous voltage drop during high current situations.
