how did model S bahave during extreme heat in NW US and SW Canada ?
It was around 37 degrees here during the heat wave on the west coast of Canada and my 2021 LR+ (non refresh) handled it fine. Only drove it about 40kms but it handled it fine, a/c worked well and I was getting great efficiency considering I have large rear tires. Was getting 135wh/km!
Upvote 0
It’s always hot here, car most always does fine. Very occasionally I’ll get a “cabin air conditioning reduced - vehicle systems cooling” message, but it only lasts a minute or two.
I supercharged at Kettleman City, CA two weeks ago when it was 114 F and got normal speeds.
Reactions: croman
Upvote 0
My 2015 S sits in the sun all day when we are not using it. Under those conditions, the 95F days we had here last week in the Boston area were pretty tough. When going out, I would precool and vent the car, and it got the cabin interior down to be tolerable, but it was still on the warm side with the temp set at 69 or 70. Oh, and I have the Tesla shades in my sunroof openings, which definitely help. Part of the problem for the passenger is that the seat (leather in our case) can get doggone hot when the car is in the sun, and does not cool down as fast as the air when you precool.
Upvote 0
I know you're talking to the Pacific Northwest, people because it got a little warm up there last week. However, those of us that live in the Southern Pacific are better suited to answer questions about heat because we get 110f+ for several months on end. Last month it was usually over 100f by 9am where I live in the Mojave desert, and that trend will usually continue till about late August.
The car does just fine in the heat, just gotta make sure cabin overheat protection is on to keep the cabin below 105f. It does eat some battery having to turn on all the time but depending on the parking situation it can vary on how often it has to turn on. My old job i had to park in the open sun and there was no shade to park under the AC was turning on and off constantly almost because the sun was just beating down on the car. But now my office has covered areas and i make sure to park in the area that will have shade for the longest period of time. It still turns on all the time but not nearly as often as it did in my last office. I also have ceramic 30% tint on all the glass except the front windshield because i had a crack at the time and they don't tint if you have a crack. So that definitely helps block some heat as well.
When driving and its 118f outside and the car Ac is set to 69f it works just fine. of course having it set like 40f lower than the outside temp does mean it will stay on running hard which eats power but whatever it works great.
For your supercharging question, its the same it works fine. However, I do not recommend sitting in the car for the first 10-15 min of supercharging when its hot AF outside because the car will divert cooling power from the cabin to the battery so it gets toasty in the cabin for the first bit of the stop. But then once the SC speed drops and the AC can keep up with cooling the battery and the cabin you're fine to hang out in there till it is done charging.
I have the original AC unit in my 2014 with 119k miles and I've lived in the desert for almost 3 years now.
On a side note, IMO the car uses less juice to keep the cabin/battery cool on hot days than it does warming the battery on cold drives. I have no actual evidence of this, its purely anecdotal based on my living in the desert and vacationing in the mountains during winter.
Reactions: pilotSteve
Upvote 0
No issues with my P85D itself, but huge issues at the older Supercharger in The Dalles, OR. It hasn’t been maintained very well over the years and the heat (118degs when I was there) did quite a number on the station. Cars would only charge for 5mins then get a red-ring-of-death. Had to unplug and re-plug multiple times over the course of an hour+ just to get enough to make it to Portland. Nosecone cars had more issues vs refresh/3/Y, but no one was immune.
I detailed the experience in The Dalles SuC thread.
Upvote 0
