How do I keep the car on?
Discussion in 'Model S: Driving Dynamics' started by shah007, Nov 21, 2016.
  1. shah007
    shah007 Member
    Reston, Virginia
    When I get out of the Model S with my wife and kid still being inside it and even if I leave the key in the car, the car still turns off. So even the sound system and heater are turned off. Is there a way to leave the car on when I am not in the car?
  2. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    If you have the new 8.0 firmware it should stay on as long as the front passengers seat belt is buckled. Otherwise just tell them to tap on the screen once you get out to turn things back on.
  3. shah007
    shah007 Member
    Reston, Virginia
    Thank you. Do I have to leave the key in the car OR can i take it with me?
  4. MP3Mike
    Oregon
    If I recall correctly you can take the key with you.
  5. SW2Fiddler
    SW2Fiddler I, for one, welcome our new Robot Axis overlords!
    Houston TX
    What I do:
    Take the key, or leave the key, step on the brake before closing the driver door.
    See if it works for what you want.
  6. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    I always just leave the keys, ever since I didn't once and my wife opened the door and the alarm (horn honking) went off.
  7. benjiejr
    benjiejr Technogeekextraordinaire
    San Antonio, Texas
    Another option that I sometimes use in this scenario is to close the driver door just to the first latch, not all the way closed. Hope that makes sense.
  8. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    You can also put the parking brake on via the touchscreen which leaves the car on.
  9. Chopr147
    Chopr147 Active Member
    Wantagh, NY
    That's what I do and it works well. Otherwise touching the screen only gets you 10 more minutes
  10. Maximapolak
    Maximapolak Member
    North NJ / SouthCentral PA
    Put it in camper mode. Put the E-brake on. Put the car in neutral. Leave the key with her and tell her to lock the car from the screen (because if she locks it from the fob, anyone can tap the handles and get in.)
  11. EVCarGUy
    EVCarGUy Member
    This is the method I use - my mailbox is part of a stack at the end of a rural road. At night, I want to stop, leave the lights on and the right turn signal. Stepping on the brake is perfect. Otherwise, the turn signal stops immediately when I get out, and the head/tail lights time out 30 (45?) seconds later leaving it an unlit hazard on the side of the road.
