How do I lock the car, walk away, but leave internal systems (i.e. HVAC) running?
Discussion in 'Model S: User Interface' started by ljwobker, May 20, 2014.
  1. ljwobker
    ljwobker Geek.
    Raleigh, NC
    I'm sure this has to be written down somewhere... but I searched for 10 minutes and couldn't find it, so apologies if it should have been more obvious.
    How do I put the car into what would be the equivalent of an ICE "accessory" mode? I basically want to be able to:
    1) park the car
    2) get out, lock the car, walk away WITH THE FOB
    3) stay away an indefinite period of time
    4) have the climate control and other internal accessories (radio, headlights, whatever) stay on
    I'm most interested in a solution to allow me to leave perishable things (like pets!) in the car with the HVAC running... and while I realize I can set the climate control via the mobile app, I'm interested in general principle in some other way to leave all the other systems up and running.
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I am not aware of a way to do what you describe without using the mobile app is the solution, though it only allows you to control the HVAC.
  3. captain_zap
    captain_zap Electron tamer
    Redmond, WA
    This method worked on a older firmware version. I just tried it briefly on 5.9 and it still seems to work.
    1. Depress brake, put car in neutral.
    2. Using the touchscreen controls (not the shifter stalk), put the car in park. The drive indicator on the driver's display will still indicate neutral.
    3. You can now leave the car, lock it, and the accessories and HVAC will stay on.
    Warning...if the headlights are in auto, they will turn on when it gets dark and stay on...until the sun comes up again.
    - - - Updated - - -
    Also...remember to turn the wipers off...if they are on auto they will start if it rains!
  4. Francis Lau
    Francis Lau P-1456
    Bellevue, WA
    This use to work. Leave the car via the front passenger door.
  5. loganss
    loganss Spaceman
    Maryland
    Could the car be driven away by someone without a FOB if using the Neutral trick?
  6. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    How do I lock the car, walk away, but leave internal systems (i.e. HVAC) runn...
    Doesn't this open up a Pandora's box of "No, it's ok my pets are locked inside the car.. The A/C is running, so don't break my windows or call the cops" signs for the windows?
    And hoping people read and understand them?
  7. Ziggy
    Ziggy Member
    You can roll down the window, get out the car, shut the door, reach in and touch the display, then roll up the drivers window without opening the door (be sure to pull your arm out fast enough so it doesn't get caught in the window), and the display and AC will stay on because the car thinks someone is still in it. :wink:
  8. mibaro2
    mibaro2 Member
    Georgetown, ON
    Yes..I can see that scenario happening a lot.
  9. loganss
    loganss Spaceman
    Maryland
    There is a set amount of time this will work but I think after that time the car will power off. This happened to me at the drive in movie theatre. I had to be in the car and use the neutral trick to keep all systems on for the duration of the movie.
  10. siai47
    siai47 Member
    Deland, Fl.
    I had a Rav4-EV and a LEAF that I took my old dog everywhere in. I had the same type of sign that I would put in the front seat. I only had one lady track me down in a panic about the dog. I thanked her for her concern, went out to show her how cool the car was inside, but she was still upset about it. I told her that the dog was much safer in the car with A/C running (and a phone message if something caused it to stop) then he would be if he were locked in my house and it caught fire. Dark window tint in the rear of the LEAF stopped any further concern about the dog. Unfortunately, the 15+ year old dog didn't last long enough (natural causes - not roasted) to enjoy the big back seat of the Tesla.
  11. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    The only way to do this, and I do this all the time, is the neutral trick. Put it in neutral, engage the emergency parking brake via the console. Then get out of the car. It'll stay on forever with all accessories running, air, music, lights, etc.
  12. selsrog
    selsrog Member
    Belgium
    so when on a (steep) hill, this is not going to be simple...
  13. NigelM
    NigelM Recovering Member
    Northern Virginia
    Just keep your foot on the brake pedal until you've engaged the emergency brake via the center console.
  14. doug
    doug Administrator / Head Moderator
    SF Bay Area
    What if the dog disengages the emergency brake?
  15. WeazL
    WeazL Moderator - Hawaii
    Oahu, Hawaii
    Yes, if they gained access into your car. But that's not likely since it's locked while you're away with the FOB. Hypothetically speaking though, yes; The FOB only needs to be present to start the vehicle. Once running it no longer needs the FOB present to change driving states. I know an MS owner who was showing his MS to a friend, and drove away while his friend still had the FOB in his pocket (accidentally)--he learned that the MS will run until the driver gets out and the vehicle powers down. Unfortunately for him, that was 22 miles away. At that point, it's time to call a friend to bring you your FOB. :cursing:
  16. Mnlevin
    Mnlevin Member
    South Florida
    Seems like a lot of stuff going on here.
    Simply get out of the car and make sure the doors are locked.
    Open the app on your smartphone.
    Go to climate, put in the temp and walk away. Nothing else to worry about. (just make sure your car has remote access turned on) works every time.
  17. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    I believe (though I'm not certain) that if you activate the HVAC from the mobile app, it turns off after some period of time (60 minutes?). Easily remedied by monitoring the car from the mobile app.
  18. NigelM
    Northern Virginia
    You place a dead cat behind one of the wheels as a chock before you leave.
    - - - Updated - - -
    Yes, but the thief has to first contend with the resident guard dog inside the car.
  19. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    The climate settings from the mobile app will run for 30 minutes. You need to interact/change a setting or restart the climate controls to extend the time.
  20. mg012
    mg012 Member
    San Antonio, Tx
    What about the security system with the pet in the car? Is there a motion detector activated? On my BMW I have to click the key fob twice to lock the car but disable the motion detector.
