How do I navigate to a contact?
KalTorak
"navigate to X” for a person in my phone book (and I know there’s an address attached) doesn't seem to work.
Is there a magic word to navigate to an address attached to a contact in my phone book?
aesculus
Still Trying to Figure This All Out
May 31, 2015
4,309
2,461
Northern California
I don't think you can. Nothing in manual alludes to this capability. You can navigate to home or work if you have set those, and of course items that are on the map or in their database. I also made sure that the contact I tried had a navigable address (pushpin on contact) and I could select it by touching it, but no voice command accepted.
Jrzapata
144
177
Texas
Tap on the phone icon in the M3 screen
Change to the contacts tab
Navigate to the desired contact
Open that name
Tap on the address
Voila!
aesculus
May 31, 2015
4,309
2,461
Northern California
Open that name
Tap on the address
Voila!
I was assuming the OP was asking how to do voice command navigation. It is confirmed you can touch the address on a contact and have it navigate.
VValleyEV
667
3,877
Cottonwood, AZ
AHA! There is a sorta kinda workaround to use the voice commands to navigate to a contact name. I knew I had found a way during my test drive before I bought my Model S, then forgot.
Here’s the deal, requiring a one-time setup for each contact that you wish to navigate to by voice command. The setup: as everyone else instructs, use the touchscreen phone contacts list to look up a name that includes an address, and use the touch screen to tell the car to navigate to that address. NOW cancel the navigation, click on navigation again, choose the most recent address you just navigated to, and hit the little heart to add to favorites. In the popup for favorites, it shows the address for a title; replace that with the contact name.
Now you will be able to navigate to that contact name by voice command, because it is in the favorites by that name.
Caveat: of course the voice recognition will have problems with some names, so you might need to spell it phonetically in the favorites list to get it right. You can’t even edit the name you gave a favorite, you have to delete it and re-add it. It can get frustrating and a bit humorous, but it does work.
At the very minimum, Tesla software should put the contact name in the recent navigation list automatically. But they really should have a “Navigate on contact XXX”. I am thinking that the use of the extra “contact” word would help avoid pulling up too many choices when you are really looking for something in google maps, and don’t want it to be confused by a contact list that is as hopelessly out of date and huge as mine.
