The red dot is lit up ( glowing) in the dashcam if it is active. When it is disconnected ( same as eject from a USB port in PC /Mac) the red dot stops glowing.
NOTE that if you use separate drives for TeslaCam and your music, you do not need to disable the cam. Either way, make sure you aren't in the middle of a song playing on USB.
Easiest way is to press and hold the big button with the camera in the main “Controls” menu. (It’s next to the “Mirrors” button and above the “Sentry” button.)
If it’s currently recording, it will say “Recording” and there will be a red dot in the camera icon. If it’s not recording, it will say “Record” and the camera icon will be greyed out.
If it’s currently record and you simply tap this button (as opposed to press-and-hold), it will save the last 10 minutes of video footage instead of pausing it.
Another way to stop recording is to go into the “Safety” menu, scroll down to “Dashcam”, and change it to “Off”.
