Note: This feature currently requires accessing the site using the built-in Safari browser.
It totally makes sense for you to do this, but is this a good thing from a broader perspective? If we can all charge at work for free during the day we will do so. But this: (1) increases peak demand which may cause more electricity generation to be built, and (2) causes more GHG emissions because additional demand during the day will be met by burning Nat Gas (at least here in Ontario - worse in other jurisdictions that still have coal) rather than generating more electricity from hydro-electric.I use a UMC if I have to charge at home. I say "if" because my work has put in a charger and I use it daily to top off my battery.
Isn't encouraging people to charge during peak demand times a bad idea (unless there is no other option)?
That's great to hear. They must have a ton of panels - doesn't a Level 2 draw 7.2kW (240V X 30A). If the panels are similar to the 250W ones on my roof that would mean about 30 panels (which are each about 1x2 m) times 36 or about 1000 panels.My employer has 36 level 2 chargers that are all powered by solar panels on the parking garage and available for free charging. The building I work in is also covered with solar panels and is net zero. Some employers are doing it right. [emoji4]
The parking garage has a 1.153 MW solar array (covering the roof and southern wall, 5 levels high) and many other buildings are covered with panels as well. There's a lot of information about it here. Here's a PDF with a little more information on the charging infrastructure. I believe the charging stations are load balanced so they aren't all producing full output simultaneously.That's great to hear. They must have a ton of panels - doesn't a Level 2 draw 7.2kW (240V X 30A). If the panels are similar to the 250W ones on my roof that would mean about 30 panels (which are each about 1x2 m) times 36 or about 1000 panels.
But I presume the chargers aren't just powered by the solar panels as otherwise there is no power on cloudy days.
