How do you clear tpms error? Its says one tire is too low but other tires are the same psi as the one the with error. I have rebooted car and that did not work..any suggestions would help..
mine took a long time to reset itself... but eventually did it on it's own.
In my experience it will only ever complain about one Tire even if multiple are low. If it's actually low you'll have to increase pressure. If not you can reset from the settings.
FWIW, just yesterday all 4 were low and I got a 'Tire Pressure Low x4' warning message.
45 might be too high. window sticker says 42. Mine was at 45 at delivery and drove ok.Your tire pressure is too low. Inflate all four tires to 45 PSI. The error message will clear after driving for about 3 minutes.
Typically, when there's a delay for things to reset, it means the car needs to go into "sleep". So, for some that means overnight; and for others, it means no time at all, because there's a procedure you can use to manually put the car into sleep.Hi Shemp, I'm curious whether long time means 20 minutes or a few days?
Then you inflated all four to the correct psi. The people who only inflate one tire will continue to see the warning as one of the other tires is out of the pressure zone. You just gotta set all four correctly.Hm. After re-inflating, mine reset the warning before we cleared the parking lot. But as you know, things vary.
I'd tell you what the procedure is, but I don't know it!
