How do you close the frunk? Have you creased it?
Discussion in 'Model S: Interior & Exterior' started by Pilot_51, Jul 28, 2014.
How do you close your frunk and have you creased it that way?
  1. Two hands between latch and side edges. Not damaged.
    61.0%
  2. Two hands between latch and side edges. Damaged.
    11.6%
  3. One hand or two hands together over latch. No damage.
    19.9%
  4. One hand or two hands together over latch. Damaged.
    2.7%
  5. Another method (please explain). No damage.
    5.5%
  6. Another method (please explain). Damage.
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Pilot_51
    Pilot_51 Member
    Metro Detroit, MI
    #1 Pilot_51, Jul 28, 2014
    I've seen a lot of discussion about closing the frunk and the dreaded crease, but nothing like a poll to give an overview of how likely each method is to cause damage. So, I made this poll. It is multi-choice so, for example, someone who damaged it with one method and changed to another method can select both.
    As far as I can tell, my frunk hasn't been creased yet, even though one untrained person closed it while I was distracted by others asking questions. I've always closed it with the two-hand method as explained in the manual and Tesla's instructional video, with varying degrees of awkwardness due to the pressure required.
    Edit: If your frunk was damaged by someone else and not by you, pick the 'no damage' option and feel free to post what you know about how it was damaged.
  2. Zextraterrestrial
    Humboldt/Los Altos
    I almost always use a knee on one corner and a hand on the other, since there would be something I just got out of the frunk in the other hand, or something I am getting in the car with if I just placed something in the frunk.
    At the factory the 'delivery specialist' said that the frunk needs to be closed with 2 hands, one on each side and then I used one hand in the middle. The look on his face was somewhat memorable (like WTF did I just say?) and there was no crease from this one time I did it. that is the only time I have used one hand in the middle
  3. William13
    William13 Active Member
    South Bend
    Very gently
  4. Merrill
    Merrill Merrill
    Sonoma, California
    I use the palms of both hands placed toward the front of the frunk and on either side of the latch area where it is reinforced.
  5. JST
    JST Active Member
    I tend to use all ten fingers, no palms.
    One feature I'd like to see added is an electric closer on the frunk. As it is, I use it only rarely, both because of a fear of damaging it and because it's a PITA to close, especially if you are holding whatever item you just took out of it.
  6. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    One hand to the first click, then two hands center of the two sides of the latch to fully close, gently. No damage yet...
  7. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    I position my rear at the front edge, so I'm facing away from the car, and do a very quick squat. Just make sure you have no rivets on your back pockets!
  8. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    I have never opened it since the DS dropped it off in Nov 2012...
  9. chickensevil
    chickensevil Active Member
    Virginia, United States
    Standard two hand method. I was worried about it and also having difficulty getting it closed until one of the service techs showed me the right way. It isn't just two hands on the sides there is a quick force downward that you do with it. I think people likely damage it by trying to go too slow and be careful that it messes it up.
    I agree that it is harder than it should be, but not so bad once you get the hang of it. Here is to hoping that they make it easier on new cars.
  10. mknox
    mknox Well-Known Member
    Toronto, ON
    Mine closes fairly easily without much pressure needed. I wonder if those getting dents have a "tighter" latch that requires more pressure?
  11. Zextraterrestrial
    Humboldt/Los Altos
    or this if both hands are full
  12. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    I used the two-handed palm base method on the edge of the frunk on either side of the latch, as instructed by my DS back in November and the old user manual. A ripple (not a strong enough edge to be a crease) in the hood was pointed out to me last week. Pretty frustrating to carefully follow instructions and still damage a multi-thousand dollar part.
    Turns out last month they changed the manual to specifically instruct you not to do that anymore, and have a new recommended technique that involves pushing on the flat part further up the hood (would fall into "Another method" in this poll, I think). Thanks for telling us. :cursing:
  13. gavine
    gavine Petrol Head turned EV Enthusiast
    Philadelphia, PA
    My DS (Norristown, PA) taught me to put both hands about 3ft apart on the aerodynamic bulges on the front part of hood and press there. That's how I do it and no crease yet. It sometimes takes me two tries to get it to latch, but it works and so far so good. I have opened/closed mine about 10 or 15 times so far.
    Those bulges seem to be a pretty strong area of the hood, however, being so far from the latch, it does require some force.
  14. liuping
    liuping Active Member
    San Diego
    I just checked the manual on "My Dashboard", but it only shows the old way for me:
    Where did you find the new method? Is it only for certain VINs?
  15. Gizmotoy
    Bay Area, CA
    That's the new way. They changed it to that in June. The previous method was to use two hands on either side of the latch along the front edge of the hood (basically where the two red boxes meet).
  16. chickensevil
    yeah, I think the key is staying off the leading edge and NOT pushing down in the dead center.
  17. LaJolla
    LaJolla Member
    La Jolla CA
    My car is only two months old, but in that time I seldom used the frunk, for fear of the dreaded crease -- which has been well-reported on this Forum as having impacted hundreds and hundreds of cars.
    Unfortunately, I just took my vehicle into a Service Center to repair part of the interior flooring, which was coming up, and whoever worked on the car opened and closed the frunk -- leaving a very noticeable crease. So, no matter how careful owners are, this significant design defect is likely to continue to cause problems as long as others -- kids and family, friends, valets, repair people -- get their hands on the frunk at least once.
  18. Pilot_51
    Pilot_51 Member
    Metro Detroit, MI
    I'm pretty sure the resistance is coming from the seal rather than the latch. If I were to guess, the reason Tesla recommends closing it with pressure to the sides rather than over the latch is to put even pressure on the seal so the sides don't get pushed up and cause a downward bend in the middle that could create the crease.
  19. chickensevil
    ummm, I hope you reported that to them. You should not be responsible for that damage!!!
  20. ntam
    ntam Member
    Bay Area, California
    I use the frunk to carry take-out two the three times per week (much reduced food smell in the cabinet though a little bit could still seep through the vent). I usually close it by using my whole forearm flat against the center edge of the lid and lean my body down to close it. I don't think I creased it yet. Another benefit of using my forearm is that I won't be leaving finger prints on the hood.
