How do you remove sliding armrests?
Discussion in 'Model S: Interior & Exterior' started by pingumel, May 11, 2016.
  1. pingumel
    pingumel New Member
    Gurnee, IL
    How do you remove the sliding armrests to remove the plastic cover underneath it? I must be missing something because I can't get it.
  2. GlmnAlyAirCar
    GlmnAlyAirCar Active Member
    Sanatoga PA
    The screws on the underside of my armrest came out, so I stopped by a service center to have them replaced. The tech told me to be ready for what he was about to do. He pulled back the armrest about half way so he could get his hand under it, then yanked it straight up. Pop! Off it came. He told me it's the way it's supposed to be done. I haven't tried it myself, but I did witness the procedure. Take my advice with a grain of salt.
    • Disagree x 1
  3. zambono
    zambono Active Member
    DC
    Se need a DIY section already
  4. Andino
    Andino Member
    Los Angeles
    Has anyone tried this with success? I need to remove the sliding armrests in order to take off the plastic protective film.
  5. Nismode
    Nismode Member
    NYC
    If the film is still whole, you don't need to. Just pull it in a way to peel off everything at once. Sliding the armrests forward makes it easier. If there's still a piece in between, I would rather use a small, thin screwdriver to peel it off rather than messing with removing the armrests personally.
  6. Andino
    Andino Member
    Los Angeles
    I tried pulling and only part of it came off. The remainder got stuck between the armrest and the opening between the armrest and the console is way too thin for any screwdriver to reach it....o_O
  7. Tes Pride
    Tes Pride Former Vendor
    O'Fallon, Mo
    Just pull the arm rest up. They pop off.
  8. Andino
    Andino Member
    Los Angeles
    Is it easy to put it back? What's the risk of damaging the whole thing?
  9. Tes Pride
    O'Fallon, Mo
    I've taken mine off many times. It is harder to put back on. You can go to the service center if you are worried.
  10. snail3
    snail3 Member
    Bay Area, CA
  11. PaulD
    PaulD Member
    Oceanside ca
    ***do not trust the craziness you see on YouTube on this ***
    In reality this is a 5 minute procedure...although scary to watch a pro do it...( I did yesterday at tesla service).
    Nothing to do but slide and yank hard. Picture below on 2015 dual slide. Then you attach new screws with licktight...align the tracks between what you removed and what is in my pic below and pound the top of the pad till it snaps to lower track. Given tesla knows of issue they did mine for free with no appointment (I called in advance to check the work load) 20180727_152801.jpg
  12. SpudLime
    SpudLime Active Member
    Leesburg, Va
    Holy F that is scary.
  13. Muzzman1
    Muzzman1 Member
    Los Angeles
    I posted this a while back. Hope this helps!
    • Helpful x 5
  14. kingleonidas
    kingleonidas Member
    Madison
    Thanks for making me crack up and spit my coffee all over the very armrest console that I want to remove so I could clean ;):D
  15. 1windy
    1windy Member
    suffolk
  16. Rockwell
    Rockwell Member
    Anaheim hills
    Just pull up .
  17. DerbyDave
    DerbyDave Member
    Kentucky
  18. Muzzman1
    Muzzman1 Member
    Los Angeles
  19. Kurtbe
    Kurtbe Member
    Ghent/Belgium
    Be careful with this procedure. As of 2017 model, things are probably different. I took out the center console and thus got the whole cup holder box off. From the bottom I can see srews that seem to hold the sliding armrests in place. It might still be possible to yank them off. But I would be careful...
